    Small question about rescaling components
    10 Posts 4 Posters 892 Views 4 Watching
    • liquid98L Offline
      liquid98
      Hello fellow scripters,
      I found this script called: 'scale_reinit.rb'.
      The script reinitializes the scale of scaled components.
      Download: http://forums.sketchucation.com/download/file.php?id=12605
      Discussion: http://forums.sketchucation.com/viewtopic.php?f=323&t=11552&hilit=reset+scale,
      edit : picture updated
      https://lh3.googleusercontent.com/-_YeyOZiymHs/Tt5E8NRoQcI/AAAAAAAABVw/N2NSH3Cyh1Y/s1440/testscalecomp1.jpg
      I'm not sure how the script works, but the components are placed in the wrong manner (see image)..
      I suppose it's a small effort to correct this..
      Any help is appreciated.. πŸ˜„
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
      • sdmitchS Offline
        sdmitch
        liquid, You might give my Resize and Rename plugin a try.
        http://sdmitch.blogspot.com/
        • liquid98L Offline
          liquid98
          Yes it works! Thanks, Sam.
          The only thing is that I have to adapt the plugin to work with more components at once!
          • sdmitchS Offline
            sdmitch
            What are you trying to do. Scale up all component definitions in a model? if so
            mod = Sketchup.active_model
            ent = mod.entities
            sel = mod.selection
            defs = mod.definitions
            defs.each{|d|
              tr=Geom;;Transformation.scaling(2.0)#2X scale factor
              d.entities.transform_entities(tr,d.entities.to_a)
            Of course scaling any one instance scales all instances of the the same component.
            • liquid98L Offline
              liquid98
              Sam,
              Yeah that's also a nice solution to my problem.
              But then I have to work with certain scale-factors...
              'scale_reinit.rb' is more hassle free. I updated the image above to make my question more clear. Hope you understand .
              • Chris FullmerC Offline
                You just want the native "Reset Scale" feature to work with more than one component at a time, right?
                All my Plugins I've written
                • sdmitchS Offline
                  sdmitch
                  That seems to be goal Chris as I understand the problem. I have been looking at scale_reinit and there are two problems with it as I see. First, you have to have all the components selected before loading the script other wise it is not added to the context menu. Second, the scaled components aren't rescaled, they are replaced with an insertion point of corner(0) or lower left of the bounding box which is exactly where the demo model shows it.
                  • liquid98L Offline
                    liquid98
                    @ Chris,
                    Yep that's right!
                    edit
                    So is it possible to call the native "Reset Scale" command from a script, and apply it to component_1.. component_i in the model?
                    • G Offline
                      guntis.rat
                      did this ever got resolved?
                      • sdmitchS Offline
                        sdmitch
                        Apparently not, at least as far as the free version of Sketchup is concerned. The Reset Scale option is available in the context menu if only one component is selected.
                        You are welcome to try my plugin, Scale Reset, which seems to have been the solution for the problem liquid98 had.
