    Ruby, Undo Stack and dynamic components
    6 Posts 3 Posters 1.9k Views 3 Watching
    • danielbowringD
      danielbowring
      Hey,
      I'm working with using dynamic components in ruby. I'm able to set attributes and have them applied as such
      ent.set_attribute(dict, key, value)
      $dc_observers.get_latest_class.redraw_with_undo(ent)
      However, doing so fills the undo stack with "Properties" and "redraw" operations, which is interfering with my own operation (which I start before the DC's are created and commit after the last redraw), as such
      def some_func()
          Sketchup;;active_model.start_operation 'My Operation'
          create_ent()
          Sketchup;;active_model.commit_operation
      def create_ent()
          ent = Sketchup;;active_model.entities.add_instance(definition, transformation)
          ent.set_attribute 'dynamic_attributes', 'some_key', 'some_value' # adds "Properties" to the undo stack
          $dc_observers.get_latest_class.redraw_with_undo(ent) # adds "Redraw" to the undo stack
      How can I ensure that my operation is the only one that appears in the undo stack, so that a single undo operation will remove all the ent, etc?
      • Dan RathbunD
        Dan Rathbun
        Have you explored the extra arguments to start_operation() ??
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          instead of redraw_with_undo( entity, progress_bar_visible=true )
          you can also use this:
          redraw( entity, progress_bar_visible=true, is_recursive_call=false )
          example in your module:
          module Bowring
            def self.dc_redraw( ent, pbar_visible=true, undo=false )
              ldc = $dc_observers.get_latest_class()
              if undo
                ldc.method(;redraw_with_undo).call( ent, pbar_visible )
              else
                ldc.determine_movetool_behaviors(ent)
                DCProgressBar;;clear()
                ldc.method(;redraw).call( ent, pbar_visible )
                ldc.refresh_dialogs()
            rescue TypeError => e
              # suppress nil to float conversion error that happens
              # when redraw is called directly with true 2nd arg.
            end #def
          end #module
          • danielbowringD
            danielbowring
            Combination of these was indeed the solution - thanks again πŸ˜„
            • danielbowringD
              danielbowring
              Another question on the undo stack, is it possible to prevent operations from appearing in the undo stack at all? To basically have transparent actions that are never added to the stack?
              In certain cases I have to show/hide entities during an input stage, and that clutters the undo stack. It's possible to move them into one operation, but the stack looks something like
              Operation 1
              hide/show-operations
              Operation 2
              Which adds an unnecessary undo step (as I undo all the operations performed in the ruby code).
              • thomthomT
                You could try with the transparency flags of .start_operation .
