    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 162.0k Views 13 Watching
    • P Offline
      Voronoï Diagram by Max Smirnov
      Select Voronoi: Name it, Select Polygon: name it
      Select Voronoi's lines
      Call Boolean Inter
      Click Polygon
      Et voilà! 😄
      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/570504_orig.jpg
      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3263482_orig.gif
      • O Offline
        olishea
        does it work in 3D?! 😄
        oli
        • P Offline
          You can make yet some things with it! 😉 (and it's work in progress! ) 🤓
          • O Offline
            olishea
            There is a [ missing from your link mate
            One day, i swear, there will be a plugin where you just click "apply pattern" and then BOOM it's done! Whatever voronoi/tessellation you like. Just couple of clicks!! One day!!! 😄
            oli
            • P Offline
              • P Offline
                FatLines by Max Smirnov
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1939476_orig.jpg
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/4303546_orig.jpg
                • P Offline
                  Delcorners by Max Smirnov
                  Voronoi, Delcorners, Flow
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/250183_orig.jpg
                  • O Offline
                    olishea
                    Smirnov is on fire! wow!
                    oli
                    • P Offline
                      New version of Subdivision by Max! 😉
                      (Trick for volumes with difficulties like here : export as OBJ with triangles
                      then _importObj (By Max 😉
                      and voilà!
                      http://s6.postimg.org/rq8zqot1t/beta7.jpg
                      • P Offline
                        • P Offline
                          Teasing by Max Smirnov
                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/6924353_orig.gif
                          • P Offline
                            A new 3.1 version of MoI (Mac version), to fix problems when running in OS X 10.11 "El Capitan" 🤓
                            else in few days! 😉
                            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=d7b79cb5632b11f9d86d52326d52d9ca&filename=SubdivBeta8-1.jpg
                            http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=cc6c689daf7fdc847147bfbe46b9b26c&filename=SubdivBeta8-2.jpg
                            We can make the same with Artisan! 😉
                            • P Offline
                              Subdivision Beta 8
                              "Open Surfaces"
                              by Max Smirnov 😉
                              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2279270_orig.jpg
                              Pig By Max Smirnov
                              http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=beefa22434ee5e33a98a64b8048b356b&filename=SubdivB8.jpg
                              • P Offline
                                beta 9 Subdivision by Max Smirnov
                                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/7203751_orig.jpg
                                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9164830_orig.gif
                                • P Offline
                                  • P Offline
                                    System KitBash objects added!
                                    https://dl.dropboxusercontent.com/u/3788438/WidgetGadgets4Moi3D/Widgets/BLIVET-SQUARE.png
                                    • P Offline
                                      Nodes arrive inside Moi! (in developpment) 🤓
                                      By Max Smirnov!
                                      • O Offline
                                        olishea
                                        Thanks for the updates Pilou! Much appreciated.
                                        oli
                                        • P Offline
                                          In fact I didn't spend a lot of time writing it. I decided to finish the main core script, and then share it with community.
                                          I still do not have plans to write the whole node-system for MoI.
                                          • P Offline
                                            This project is very close to alpha release
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 7 / 11
