    Another SP functioning video...well
    6 Posts 2 Posters 628 Views 2 Watching
      tspco
      I tried to make a working trebuchet, and failed three times to get the "swing" right. So I opted for a hightech version a "Rotary Trebuchet". Using a sphere as an emitter and tweaking the UI settings for a continuous supply of ammo. Here it is. needs more tweaking though.
      [flash=420,315:130lzer2]http://www.youtube.com/v/Vgvu8JaJ8e4[/flash:130lzer2]
      I would like to get the timing right, one ball per paddle, good throws at least 90% of the time.
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • X Offline
        xrok1
        try dropping thr balls from higher so there dropping faster and make it further into the arms 🤓
        might work to curve the arms slightly forward too?
        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          tspco
          I tried to do a rework but I broke it, with side flanges, and the higher drop, it might work if I can fix it. Of course I reworked the working model, anhd I don't have a copy.
          Rule Number One in SketchyPhysics, save your work often. Rule Number Two, if you want to redo something make a copy and rework the copy, save your working original, if for nothing else for use as a reference.
          • X Offline
            xrok1
            and upload it with your post so others can play 😉
              tspco
              I will do that, now it is spinning with the modified flanges, but the balls won't grop into the wheel.
              OK here you go, share yout tips please!
                tspco
                New modified version without flanges. The flanges would be cool, with a V-mod on the center of the wheel, so the balls don't land in a straight line, more random placement, in theory anyway.
                rototrebwf.skp
