    Another SP functioning video...well
    6 Posts 2 Posters 729 Views 2 Watching
    • T
      tspco
      I tried to make a working trebuchet, and failed three times to get the "swing" right. So I opted for a hightech version a "Rotary Trebuchet". Using a sphere as an emitter and tweaking the UI settings for a continuous supply of ammo. Here it is. needs more tweaking though.
      [flash=420,315:130lzer2]http://www.youtube.com/v/Vgvu8JaJ8e4[/flash:130lzer2]
      I would like to get the timing right, one ball per paddle, good throws at least 90% of the time.
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • X
        xrok1
        try dropping thr balls from higher so there dropping faster and make it further into the arms 🤓
        might work to curve the arms slightly forward too?
        • T
          tspco
          I tried to do a rework but I broke it, with side flanges, and the higher drop, it might work if I can fix it. Of course I reworked the working model, anhd I don't have a copy.
          Rule Number One in SketchyPhysics, save your work often. Rule Number Two, if you want to redo something make a copy and rework the copy, save your working original, if for nothing else for use as a reference.
          • X
            xrok1
            and upload it with your post so others can play 😉
            • T
              tspco
              I will do that, now it is spinning with the modified flanges, but the balls won't grop into the wheel.
              OK here you go, share yout tips please!
              • T
                tspco
                New modified version without flanges. The flanges would be cool, with a V-mod on the center of the wheel, so the balls don't land in a straight line, more random placement, in theory anyway.
                rototrebwf.skp
