    Ruby Code Generator
    5 Posts 3 Posters 824 Views 3 Watching
    • C
      Chris88
      Hey,
      is there someone, who knows how to code a ruby-code-generator in C#?
      Probably with ironruby in visual studio..
      Because i need a code generator in C#, which generate
      ruby-code, which it can execute in sketchup.
      Thanks.
      • Chris FullmerC
        Why do you need this contraption? And how much code do you need to generate? I don't know much about "code generators" in general, but this sounds odd.
        All my Plugins I've written
        • C
          Chris88
          ok, i think i need to explain it in more detail:
          my C#-programm read a lot of XML-documents (which it could transform to TXT with XSLT), on the basis of these values my programm should generate many ruby-files, which will be executed in SketchUp.
          If i code the ruby-files by hand, one ruby-file have ca. 2000-5000 lines (and i need many ruby-files), so it's more comfortable to generate the code. (it's a query, whether values exists in the XML/TXT or not -> a lot of if's)
          • Dan RathbunD
            Dan Rathbun
            1) You would not use "a lot of if's", instead you would use a looping block statement of some kind in Ruby.
            2) It makes more sense, to use the XML and XSD library files from the Standard Ruby Library. (You need a full Ruby install to have the Standard library files.)
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              And I see you just joined SCF, so I'll assume your new to Ruby... see:
              Ruby Newbie's Guide to Getting Started
              Get the CHM Ruby Reference, as instructed in the Guide...
              Get the full Ruby installer:
              Ruby (v1.8.6-p287) Windows One-Click Installer
              Get the !loadpaths.rb script (so you can access standard Ruby lib files):
              [Code] Ruby LOAD PATHs script (Win32) (Dan Rathbun / Jim Foltz)
