Ruby Code Generator
Hey,
is there someone, who knows how to code a ruby-code-generator in C#?
Probably with ironruby in visual studio..Because i need a code generator in C#, which generate
ruby-code, which it can execute in sketchup.Thanks.
Why do you need this contraption? And how much code do you need to generate? I don't know much about "code generators" in general, but this sounds odd.
ok, i think i need to explain it in more detail:
my C#-programm read a lot of XML-documents (which it could transform to TXT with XSLT), on the basis of these values my programm should generate many ruby-files, which will be executed in SketchUp.
If i code the ruby-files by hand, one ruby-file have ca. 2000-5000 lines (and i need many ruby-files), so it's more comfortable to generate the code. (it's a query, whether values exists in the XML/TXT or not -> a lot of if's)
1) You would not use "a lot of
if's", instead you would use a looping block statement of some kind in Ruby.2) It makes more sense, to use the
XMLandXSDlibrary files from the Standard Ruby Library. (You need a full Ruby install to have the Standard library files.) -
And I see you just joined SCF, so I'll assume your new to Ruby... see:
Ruby Newbie's Guide to Getting StartedGet the CHM Ruby Reference, as instructed in the Guide...
Get the full Ruby installer:
Ruby (v1.8.6-p287) Windows One-Click InstallerGet the !loadpaths.rb script (so you can access standard Ruby lib files):
[Code] Ruby LOAD PATHs script (Win32) (Dan Rathbun / Jim Foltz)
