    Load & Put Components Together
    5 Posts 2 Posters 574 Views 2 Watching
      Chris88
      Hey,
      I want to put 2 - 4 componentes together, without hardcoding the
      coordinates of the componentes.
      For example:
      so i show you what i've programmed:
      driller= Sketchup.active_model.definitions.load("\\driller.skp") pos_driller =Geom::Point3d.new 47,32,25<- that's the problem
      ` set_driller= Geom::Transformation.new pos_driller
      instance1 = entities.add_instance driller, set_driller
      cuboid_wood = Sketchup.active_model.definitions.load("\Cuboid_wood.skp")
      pos_cuboid = Geom::Point3d.new 0,0,0<- like here set_cuboid = Geom::Transformation.new pos_cuboid
      instance2 = entities.add_instance cuboid_wood, set_cuboid`
      but this is hardcoded
      and i want that the computer places the objects correctly together automatically,by calculating the best position, but i can't calculate the size of these objects, because i don't know how. (i would have to measure the size with the measure-tool in SU with the mouse, but it should retrieve the values with a method)
      Or is there another possibility to avoid the harcoded way?
      I have the task to do that with many components, that's why i wouldn't
      say the detailed coordinates for every components, which i load.
      the programm should be able to load componentes, put it together correctly and dynamically, take some photos in different perspectives, save these pictures, clear it all and start at the beginning with other components ... everthing is quite clear to me, with the exception of the hardcoded coordinates of these objects
      Thanks for your suggestions.
      Greets
      • sdmitchS Offline
        sdmitch
        Chris88,
        The simplest way to determine the size of a component is to use the bounding box of the component. For example, if you wanted to assemble the components in the X direction, calculate the distance between the center points, calculate the new center point for instance2, define the transformation to move it there, then do the transform.
        bb1 = instance1.bounds
        ctr1 = bb1.center
        halfx1 = (bb1.max.x-bb1.min.x)/2.0
        bb2 = instance2.bounds
        ctr2 = bb2.center
        halfx2 = (bb2.max.x-bb2.min.x)/2.0
        ctr_to_ctr = halfx1 + halfx2
        new_ctr2 = ctr1.offset(X_AXIS,ctr_to_ctr)
        mov_cuboid = Geom;;Transformation.new(new_ctr2-ctr2)
        instance2.transform! mov_cuboid
        http://sdmitch.blogspot.com/
          Chris88
          Thank you very much, sdmitch!
          It sounds very good, i will test it at once.
          Do you know another way to assemble components dynamically?
          Because you said that this is the easiest way.
            Chris88
            It doesn't work correctly,
            my tool (driller, saw,...) is set right beside the wooden cuboid, although i put the cuboid on 0,0,0.
            Then i changed your code a little bit to:
            mov_cuboid = Geom;;Transformation.new(ctr1)
            so the tool is in the middle of cuboid, but i can't change the height of the tool or just x,y-coordinate
            • sdmitchS Offline
              sdmitch
              Chris, The code works perfectly as far as it was designed to do and that was to place instance1 beside instance2. Only you know how you want and need the components to be related to each other and only you have the components to work with.
