    TypeError: can't convert into Array
    15 Posts 4 Posters 1.1k Views 4 Watching
    • thomthomT
      I got a custom class inherited that include Enumerable. The class also has a #to_a method.
      When I use it for an operation that requires an Array I get this error:
      Error: #<TypeError: can't convert TT::Plugins::QuadFaceTools::EntitiesProvider into Array>
      Granted it's not an Array, but it says it cannot convert the object - which makes me wonder why since it has an #to_a method. The error seems to me that it tries to convert to array - but the behaviour says otherwise...
      Am I assuming incorrectly?
      A simplified example:
      <span class="syntaxdefault"></span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">Foo</span><span class="syntaxkeyword">;&nbsp;</span><span class="syntaxdefault">def&nbsp;to_a</span><span class="syntaxkeyword">;&nbsp;[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">2</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">4</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">];&nbsp;</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">;&nbsp;</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">nil<br /><br />f</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Foo</span><span class="syntaxkeyword">.new<br /></span><span class="syntaxcomment">#<Foo;0x15259760><br /><br /></span><span class="syntaxdefault">x</span><span class="syntaxkeyword">=[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">4</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">6</span><span class="syntaxkeyword">]<br />[</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">4</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">5</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">6</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">x&nbsp;</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">f<br />Error</span><span class="syntaxkeyword">;&nbsp;</span><span class="syntaxcomment">#<TypeError;&nbsp;(eval);155;in&nbsp;`|';&nbsp;can't&nbsp;convert&nbsp;Foo&nbsp;into&nbsp;Array><br /></span><span class="syntaxkeyword">(eval);</span><span class="syntaxdefault">155<br /></span><span class="syntaxkeyword">(eval);</span><span class="syntaxdefault">155</span>
      • Chris FullmerC
        I just tried it, and it worked for me. Check syntax? Take your class object and check what methods are available to it. maybe its not getting defined? Or maybe it gets overwritten somehow?
        EDIT: Nevermind, I did not really try it very thoroughly. ignore my confidence above. 😳
        All my Plugins I've written
        • J
          Jim
          I think Enumerable requires that your class implement a .each method. Some Enumerable methods also need a <=> method (comparison) defined.
          • Dan RathbunD
            Dan Rathbun
            Which implies that mixin module Comparable also needs to be mixed in, at some level.
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              The #to_a method can come from more than one ancestor.
              For instance... the basic source of the #to_a method, comes from Object which states:
              Returns an array representation of obj. For objects of class Object and others that don’t explicitly override the method, the return value is an array containing self. However, this latter behavior will soon be obsolete.
              This implies that custom classes need to override the #to_a method, so Ruby can know how to do the conversion.
              OR... the #to_a method can come from Array, if the custom class, is some descendant level subclass of Array. Which, referring to the docs:
              Returns self. If called on a subclass of Array, converts the receiver to an Array object.
              Note: That Array itself, has Enumerable mixed in, but it appears (looking at the C source,) that the "mixing" is done first.. then the Array class definition overrides the method inherited from Enumerable, with it's own edition of the method.
              • thomthomT
                I do have an .each method implemented. But in any case would that matter for converting to an Array?
                I manually added an #to_a method to my that returns an array. So I don't understand why it raises this error...
                • J
                  Jim
                  You need to yield in your .each iterator.
                  Something like this (not tested.)
                  @entities.each{|e| yield(e)}
                  See also: block_given?
                  Here's a related article about the performance of passing blocks: http://mudge.github.com/2011/01/26/passing-blocks-in-ruby-without-block.html
                  • Dan RathbunD
                    Dan Rathbun
                    @thomthom said:
                    I manually added an #to_a method to my [class] that returns an array. So I don't understand why it raises this error...
                    Is the superclass one of those API C++ collection classes ? Most of these give us problems when we try to subclass them.
                    • thomthomT
                      It does that.
                      But I fail to see why .each got to do with converting to an array when I have a .to_a method ... ? I've been searching for info on it, but I cannot find anything.
                      • J
                        Jim
                        @thomthom said:
                        It does that.
                        Sorry, I was looking at your latest bitbucket repo, which must not be your latest version.
                        • thomthomT
                          No - it's still on my computer. A larger rewrite. The one at the repo was just an early framework WIP.
                          • thomthomT
                            Off course, x | f.to_a works, but since the error message indicate some conversion was tried, I wonder why the .to_a method wasn't used.
                            • J
                              Jim
                              use .to_ary although I don't have a good explanation yet.
                              class Foo
                                def to_ary
                                  [1,2,3,4,5]
                              This is as close to an explanation as I could find: http://stackoverflow.com/questions/766712/make-an-object-behave-like-an-array-for-parallel-assignment-in-ruby/768201#768201
                              • thomthomT
                                Thanks!
                                Class: Array (Ruby 1.8.6)
                                Class : Array - Ruby 1.8.6
                                (www.ruby-doc.org)
                                Returns a new array. In the first form, the new array is empty. In the second it is created with size copies of obj (that is, size references to the same obj). The third form creates a copy of the array passed as a parameter (the array is generated by calling to_ary on the parameter). In the last form, an array of the given size is created. Each element in this array is calculated by passing the element’s index to the given block and storing the return value
                                So it appears what happens is not that f.to_a is called, but instead Array.new( f ) - and Array.new uses .to_ary .
                                • Dan RathbunD
                                  Dan Rathbun
                                  Actually (if you use the CHM Ruby refdoc,) the source shows that the #| method explicitly calls:
                                  %(#0000BF)[arg2 = to_ary(arg2);]
                                  ie, it makes a copy of the second arg to use locally (within its body.)
