    SUNSET HOUSE WITH DIRT MAPS
    11 Posts 8 Posters 1.2k Views 8 Watching
    • D
      davidh
      Attached are 2 images,a post produced one and the original render.I added some dirt maps and staining along with some planting to the garden.Finally I revised the colour tones and just brightened up the overall image.I think the wall lights are a bit too strong in the final image,I will probably go back and reduce their intensity a small bit.
      • tademaT
        tadema
        Perfect
        • S
          sketchgeek
          david you are quite the expert with sunset, rain, and dusk runders...excellent post work as always! You really know how to add a lot of life/realism to a flat dull render.
          Marc
          • R
            ramy_ramroum
            very good work
            i likeyour PNG tree
            were did you found it please ?
            thanks
            • S
              sexydevil01
              Perfect once again !!! πŸ‘
              • T
                turbobrad
                Nice work. Very inspiring.
                BradE
                Dean3Design
                • FrederikF
                  Frederik
                  Really nice...!
                  You sure have done a lot of post pro in this...
                  My crit would be on the light reflections on the grass area, which gives this render away... 😐
                  Cheers
                  Kim Frederik
                  • D
                    davidh
                    Thanks for the comments guys.I have reuploaded the sunset image with the wall light intensity reduced.the second image is what the post-pro image looks like with dirt maps but without colour correction.The third image is an attempt to use the same render and create a darker,later evening feel.
                    • R
                      renderlessman
                      Hello.
                      I like the way you work with yours renders.
                      Could you give some tips about dirt maps - how you use them.
                      I'm guessing you use V-ray for Sketchup for your renders?
                      P.S.
                      I'm not a smart guy or worse but You added some ivy in the front wall (small one next to cars) but there is non in the window reflection.
                      Just a small detail i think.
                      Cheers mate:)
                      • D
                        davidh
                        Hi Renderless,
                        I noticed the lack of reflection just after I uploaded the revised image.I will add it in later.I have previously uploaded a few dirt maps and an explanation as to how I use them in photoshop(http://forums.sketchucation.com/viewtopic.php?f=81&t=38091)
                        These images were rendered in Maxwell.
                        Attched are 2 more images,an original raw render and a post processed view of the rear of the house.I will have to revise the roof as the reflection map is too small and looks too patchy.
                        • D
                          davidh
                          A collection of the images for this project so far.
