    Multiple line select
    4 Posts 3 Posters 417 Views 3 Watching
    • T
      Thomas214
      I have a simple written code to create a wall from a selected line, now I would like it to work for multiple lines. what is the fastest way to do it without to much changing the code. Can I do it with Loop and how??
      • thomthomT
        You're making a big assumption here - we have no insight to your code...
        As for making a wall from selected set of lines, I'd create it using Face.followme method. http://code.google.com/apis/sketchup/docs/ourdoc/face.html#followme
        Create the profile of the wall at one of the end points of your set of edges and then face.followme.
        • T
          Thomas214
          In the attachment is the code.
          Wall.txt
          • Dan RathbunD
            Dan Rathbun
            There IS a work-in-progress on a BIM type plugin that can make walls, and export to IFC.
            Maybe you could join in with that project ??
            [Plugin] bim-tools 0.9.0 (8 Oct 2011)
            I'm not here much anymore.
