    Did I break Artisan?
    Scheduled Pinned Locked Moved Organic Modelling
    9 Posts 3 Posters 8.6k Views 3 Watching
    • boofredlayB Offline
      boofredlay
      Why is this happening? I don't remember the mesh on the backside of a solid being affected by the sculpt brush. Is there a setting I am unaware of?
      Thanks.
      [flash=853,505:1by9k33p]http://www.youtube.com/v/K9LxyVKPXl8&fs=1[/flash:1by9k33p]
      • soloS Offline
        solo
        lol, you have symetry on?
        http://www.solos-art.com
          boofredlay
          No I don't. If I did you would see the plus sign on the back side and the sculpt would be higher on the back side. I have tried this with symmetry on and off but to no avail, the backside is always being sculpted.
          • mitcorbM Offline
            mitcorb
            Did you have a recent Black Ops update?
            Looks like you worked that punching bag over pretty good.
            TIG mentioned that he changed a piece of code in one of his very recent scripts? And maybe you are testing a previous version?
              boofredlay
              No, I have not installed or updated any plugins recently. Nor am I Beta testing anything right now.
              I am finding some more odd results as well.
              If I subdivide a simple box Artisan seems to sculpt just fine. If I subdivide a box with segments then I get the problem again. See here...
              [flash=853,505:2cfhogdw]http://www.youtube.com/v/Va2cBErVKsw&fs=1[/flash:2cfhogdw]
              • mitcorbM Offline
                mitcorb
                Well, it was SuperDrape that I was thinking of. If that's ruled out, I don't know.
                • mitcorbM Offline
                  mitcorb
                  S.W.A.G.:Could you have somehow generated some internals and your amplitude is high, and your radius is small, and this combination somehow creates the effect?
                    boofredlay
                    Well I think I figured it out. It seems if there are quads Artisan does not respond well. If this was always the case then I am sure I probably knew about it before but just forgot. Anyway, I have solved what I need for the time being. Thanks mitcorb and Pete for chiming in.
                    [flash=853,505:kbk30zr8]http://www.youtube.com/v/iG7vn3q8lYk&fs=1[/flash:kbk30zr8]
                    • mitcorbM Offline
                      mitcorb
                      Thanks Boofredlay:
                      I will pack this little tidbit away in case it comes up again. I figure, based on your excellent previous demos, if anybody is gonna "break" Artisan, it might be you. 💚
