    [Plugin] Component Array (Updated 27-Mar-2014)
    32 Posts 13 Posters 48.3k Views 13 Watching
      tolifiers
      Hello from Theo
      This plugin is just about what i am looking for
      we are laying steel decking for a flooring company on autocad
      sketchup seems to be able to do a better job than most of the 3d cad programs about
      revit the office is not interested in vector works is to bulky in its menu structure
      to make you productive, and sketchup has some great add ons for detailing etc
      How do i get around that fact of having to lay steel decking onto shapes that are not always rectangular on sketchup, ie taking a profile or a component made from this profile and making it fill a sketchup face of any shape.
      lets know if your tool can do this or can be modified or if you know of a tool that can do this, these steel profiles are 600 wide of any length that suits its purpose,
      concrete floors are poured over this once laid.
      many thanks regards Theo e-mail theoolifiers@gmail.com
      • sdmitchS Offline
        sdmitch
        @tolifiers said:
        Hello from Theo
        No, Component Array was not designed to do anything like that. My FloorGenerator, which accepts a width and maximum length would be the closest match. If possible, post a sample model that demonstrates what you are trying to do. I have other unpublished plugins that might be adaptable to your needs.
        http://sdmitch.blogspot.com/
          tolifiers
          Hello from Theo
          Many thanks for your reply.
          Please find attached a detail and sample of steel decking
          i am trying to fill an area with the steel decking shape not sure
          how to go about it.
          I am trying to figure out the best program to make doing these drawings
          easier for install and detailing, autocad has been good till now
          but as always every thing is wanted faster, and i am not sure that 3d
          is the answer , but so far sketchup is looking the better option
          to lay decking quickly in 3d, time will tell, vectorworks is a pain to use
          revit is ok, but laying decking and trying to trim it is or will be
          too time consuming.
          sketchup may be the best option if the shape can fill an area quickly ?
          there are examples of 3 different shapes as we might find on a building
          area where we have to lay different styles of metal decking.
          its not easy to do in revit or any cad 3d program with out a lot of hassle
          trimming off excess deck manually.
          Easy in autocad, just use trim.
          3D is another story and i think sketchup will be the easiest program to do this
          These steel decking sheet come in any length some span over
          2 beams others 3 beams max length for handling is about 10m
          i am just trying to find an easy way to fill an area with the sheets
          and have it automatically trim off to a defined shape.
          the sheets lap at 600mm length ways.
          see 3d detail of some sample sheet styles and bolts to hold slab in place.
          Thanks Regards Theo
          flooring-profile-sample.skp
            tolifiers
            Hello from Theo
            screen image attached from autocad so you can see what this office
            is doing with steel decking
            we are flat out.
            Regards Theo
            • sdmitchS Offline
              sdmitch
              Theo
              Doh!!!!! I forgot to mention I'm stuck on SU2014 so I am unable to open the model posted.
              The screen shot at least gives me some idea of the problem.
                tolifiers
                Hi from Theo opps sorry here is a version 8
                thanks for that
                Regards from NZ as attached
                  tolifiers
                  From Theo PS that screen shot is one i am working on right now
                  One of the worst sites its all sorts of angles
                  more often they are rectangular in shape with stairs cut out
                  or offset corners, but this one is all over the place
                  Autocad is a good option to edit easily
                  but the office has thoughts on going 3D mmmmm good and bad idea.
                  it slows things down. So am thinging sketchup is a better option than vector works and revit, and seeing some architects do great detailing using sketchup
                  no harm in doing the same, so will keep at it.
                  Thanks Theo
                  • P Offline
                    pcmoor
                    I suggest that " profile builder 2 " would best suited to this layout and take off, the profiles can be trimmed or extended to the angles
                      tolifiers
                      Hi from Theo
                      many thanks i will give it a go.
                      have a busy week.
                      • K Offline
                        Klavere
                        First of all thanks a lot for this plugin! It just saved me a lot of time.
                        I know this post is old, but this is the best plugin of its kind and I just have a question:
                        Is there a way to update this plugin, so it's possible to pick several faces at the same time?
                        When you work with small surfaces it's really hard, and slow, to pick them all
                        And if it's not possible, is there any plugin that does exactly that?
                        Have a good day
                        • K Offline
                          Klavere
                          Have a good day
                          One year later, and I still haven't found a component array plugin that allows you to pick several faces at once
                            @klavere said:
                            One year later, and I still haven't found a component array plugin...
                            Could be a sign that you should write that plugin.
                            • 2 / 2
