    Modeling paper
    Scheduled Pinned Locked Moved Organic Modelling
    6 Posts 2 Posters 8.2k Views 2 Watching
      leminilab
      I have this assignment for a stage design for which I must draw my inspiration from this:
      http://www.constanceguisset.com/index.php?/scenographie/le-funambule/
      My client really wants to have paper stripes falling from the ceiling and rolling on the stage randomly and making waves and whatever crazy random shapes paper does...
      I can think of a way to do it using curviloft for example but it's going to be very time consuming modeling a few stripes...
      Hence my questions to you guys: do you think of a better/more simple way to model this...
      πŸ˜•
      Thanks for checking this!
      • "Live every day as if it were your last and then some day you'll be right."
      • "ThomThom rules!!!"
        driven
        idea before sleep...
        20 second attempt...
        there's lots of curvy lines in draw_metal then use TIG's vector puller,
        and I'd probably use Fredo's Taper scaling as well...
        john
          leminilab
          [attachment=1:1rdrd1sp]<!-- ia1 -->draw_metal+extrude_vector.png<!-- ia1 -->[/attachment:1rdrd1sp]
          john
          Hi! Thank you very much for your help!
          I ended up doing something quite similar to what you did with curve maker.
          I didn't know of vector puller so I duplicated my curve and used Curviloft to make the junction between my two curves (longer...).
          Here's the result after a little more tweaking, populating a circle with two different instances and placing three different colors spotlights pointing up:
          [attachment=0:1rdrd1sp]<!-- ia0 -->paper drops.png<!-- ia0 -->[/attachment:1rdrd1sp]
          This is close enough to the effect I was looking for! I'll now have a look at vector puller to see how it can make me save time in the future 'sounds like it's gonna be a LOT!).
          Thanks again for your dedication and have the nicest day!
          P.S.: How would you use taper scaling?
            leminilab
            Sorry to bother you again but I can't seem to find the plugin you're mentioning... πŸ˜•
            Can anyone point me to this vector puller?
            EDIT: found it here: http://forums.sketchucation.com/viewtopic.php?t=25293
            Thanks a lot driven and TIG! 😍
              driven
              sorry,
              thought I'd replied to say it looked great... must of forgot,
              I was just 'short-handing' the Fredo Scale's http://forums.sketchucation.com/viewtopic.php?t=17948#p144180ability to taper anything.
              john
                leminilab
                Thank you very much for your precious help!
                Take care.
                Nicolas
