    [Code] Creating attr like methods
    8 Posts 3 Posters 1.5k Views 3 Watching
      I have a set of classes where I'd like to use attr like syntax to define some properties for each class. Each of these classes inherit from a base class. I was wondering if it was possible to define your own attr like syntax?
      <span class="syntaxdefault">class Hello </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MyBaseClass<br />  foo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">lorem</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">ipsum </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
      The simple solution:
      <span class="syntaxdefault">class MyBaseClass<br />  private </span><span class="syntaxcomment"># Not required, but I like to scope'em.<br /></span><span class="syntaxdefault">  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">foo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">*</span><span class="syntaxdefault">args </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment"># Do magic stuff!<br /></span><span class="syntaxdefault">  end<br />end<br /><br />class Hello </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> MyBaseClass<br />  foo</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">lorem</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">ipsum </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
      It was pretty much what I had tried before posting the question, but I'd forgotten to add self. ... 😳
        Found the solution here: http://www.vitarara.org/cms/ruby_metaprogamming_declaratively_adding_methods_to_a_class
        • Dan RathbunD Offline
          Dan Rathbun
          I really think they missed an attr-like method for modules and classes that creates and inits class @@ vars.
          I'm not here much anymore.
            Aye!
            • tbdT Offline
              tbd
              maybe add an example in this thread (maybe original post) to have it for further searches. thanks.
              SketchUp Ruby Consultant | Podium 1.x developer
              http://plugins.ro
                Done!
                  Dan Rathbun
                  Need to prepend the subject with "[Code]" so Jim's indexer will 'snag' it ...
                    Doubledone!
