    Help with WebDialogs
    5 Posts 3 Posters 300 Views 3 Watching
      joshb
      I'm trying to follow the techniques outlined in the link below to interact between ruby and a web dialog
      http://sketchupapi.blogspot.com/2008/02/sharing-data-between-sketchup-ruby-and.html
      I've got the Javascript to Ruby callbacks working just fine but am running into some weirdness going the other way. My code is below. Whats happening is that as is, the javascript doesnt execute. If I uncomment the messagebox line, then it does. Are there any known quirks to be aware of? Or is the messagebox line doing something that is required and can be accomplished in some other way?
      I'm new to ruby and appreciate the help.
      Thanks,
      Josh
      def LaunchGenericEditor
      create a new web dialog
      editor = UI::WebDialog.new("Generic Editor", false, "Generic Editor", 275, 100, 50, 50, true)
      load the editor html and show the web dialog
      html_path = File.dirname(File.expand_path(FILE))
      html_path << "/GenericEditor.html"
      editor.set_file(html_path)
      editor.show
      strCommand = "addRowTest(5)"
      #UI.messagebox strCommand
      editor.execute_script(strCommand)
        You need to wait for the HTML to load.
        I use a callback from the JS in the WebDialog to SketchUp when the HTML DOM has loaded. When the DOM has loaded you can start using wedialog.execute_script.
        For more reading on WebDialogs: http://forums.sketchucation.com/viewtopic.php?f=180&t=23445&p=324694
        • Dan RathbunD Offline
          Dan Rathbun
          Josh.. ONLY class and module identifiers are capitalized camel-case. Methods are lowercase with underscore separated words.
          And you need to keep the 'handle' to the dialog outside the method. (or the dialog will go out of scope when the method call ends.) I usually have the dialog setup method return the handle as the last statement.
          I'll use a instance var or a module var to hold the handle.
          module Josh
            module WebEditor
              @@editor = nil
              class << self
                def launch_generic_editor()
                  # setup code here
                  return editor
                end #def
              end # proxy class
              # further down
              if not @@editor
                @@editor = launch_generic_editor()
              @@editor.show()
            end # WebEditor
          end # Josh
          I'm not here much anymore.
            joshb
            Thanks guys! Calling back to ruby from the onload did the trick. I'm obviously new to ruby and appreciate all the pointers.
            Thanks again for the help
            Josh
              Dan Rathbun
              Pay attention to the "Sticky" threads at the top of the forum. (They have the "S" in them.)
              This will get you going:
              Ruby Newbie's Guide to Getting Started
