    Advice : Developing Ruby extension for Sketchup (Windows)
    4 Posts 4 Posters 525 Views 4 Watching
    • N
      nicholas_yue
      I tried looking for the information at the FAQ.
      I am writing a C++ based Ruby Extension for use in Sketchup.
      Where can I find information regarding the C++ compiler version and Ruby version required for easier integration with Sketchup?
      Should I build my own version of Ruby ? Should I avoid developing in 64bit windows ?
      I am targeting Sketchup version 8.X
      Regards
      • Chris FullmerC
        Well, much of what you do as far as basic SketchUp extension - plugins if you will - is actually done in Ruby. The integration with SketchUp as a software is done in Ruby. Interfacing with a .skp file directly though is where you would need the C sdk.
        So if you need to write .skp files, or read them, then you will need the C sdk. Otherwise, plan on getting into Ruby. And here is the API:
        Error 404 (Not Found)!!1
        (code.google.com)
        All my Plugins I've written
        • thomthomT
          C++ ? Ruby Extensions are normally written in C.
          TBD got a simple C Extension sample which allowed me to get started with making a C Extension that worked in SketchUp Ruby. (Mine just crashed when I followed the tutorials for plain vanilla Ruby when I tried it inside SketchUp.)
          OpenSUP/SUExt at master · TBD/OpenSUP
          Open SketchUp Projects. Contribute to TBD/OpenSUP development by creating an account on GitHub.
          GitHub (github.com)
          • Dan RathbunD
            Dan Rathbun
            You have read the FAQ page I made?
            [Info] C/C++ Ruby extensions & SketchUp plugins
            I'm not here much anymore.
