    Modeling ocean wave
    Scheduled Pinned Locked Moved Organic Modelling
    16 Posts 7 Posters 13.1k Views 7 Watching
    • L
      lapx
      How do you model somthing like this or some form that similates an ocean wave? I'm have the challenge of modelling a wave that will have to be eventually built at some scale. I have a challenge thinking of how to make the form in sketchup first. Any sugestions on a method would be greatly appreciated.
      Thanks!
      • R
        Roger
        http://www.thomasparkerwilliams.com/b_ab_ed_ocean_wave.htm
        http://jungianwork.files.wordpress.com/2010/10/ocean-wave-jj-001.jpg?w=300&h=200
        http://www.flickr.com/photos/25388944@N05/4526786611/in/photostream/
        http://www.azcreative.com
        • KrisidiousK
          Krisidious
          nice Roger...
          By: Kristoff Rand
          • L
            lapx
            Thanks Roger,
            I'm exploring options and will maybe post some ideas when I get a chance.
            • soloS
              solo
              Help me understand your need...
              You want to model a wave similar to top image,then build it? Is this for a stage set, prop or will it have some function?
              How big will it need to be?
              I was thinking of using Artisan to get the form, I think it could be pretty easy to achieve, never tried it yet however.
              http://www.solos-art.com
              • GarethG
                Gareth
                hmmmmm....it is possible
                ..i have had a quick shot at it....10 minutes in SketchUp and 20 minutes in Twilight...this is quite raw but it shows that it might be achievable with a bit more time and thought
                ..i've used a simple profile for the wave, but in reality it should taper...it should be able to be done quite simply
                ..the wave would also need some 'froth'....perhaps that is something you could add in post pro
                ..anyhow, here is my quick and easy attempt....i think has some possibilities with a bit more time spent on it
                • GarethG
                  Gareth
                  same raw model with a different sky background
                  ...once again, about 20 minutes rendered in Twilight
                  ...i should add that the water material is is from one of Majid's collection
                  • R
                    Roger
                    Lapx, did you ever finish the wave, how did it turn out?
                    --Roger
                    • oganocaliO
                      oganocali
                      I gave it a try. The renderer is vray. Rendering time is > 30 mins (I quit checking after that). The basic shape is easy but I think it takes a lot of experimentation to get such a majestic wave as in the reference pic. I have no idea how to get natural looking froth and mist.
                      • mitcorbM
                        mitcorb
                        Here's what I've got. No render. I can post more if you are interested.
                        progressive profile scaling and deformation with artisan sub and smooth
                        • R
                          Roger
                          [attachment=0:3dol85fe]<!-- ia0 -->crest.jpg<!-- ia0 -->[/attachment:3dol85fe]
                          Ogan, How may views would photoScan need to process a project like this. You could radio trigger 6 cameras with 1000sec shutter speed to produce 6 simultaneous views from different angles.
                          I know this would be expanding the frontiers of the technology, but this is exactly what I am interested in.
                          • oganocaliO
                            oganocali
                            Water surface is too reflective for automatic surface generation in photoscan, but then again the small waves and froth might produce enough of a signal. For calibration and semi-automatic modeling this scene should be doable. 6 remote triggered cameras with 1/1000 shutter speed sounds exciting. you should be able to handle fast sports action with some accuracy. A sprinter (fastest) running around 10 meters a second would move around 1 cm in that 1 milliseconds. (that would also appear as a motion blur). If the synchronization of the cameras is better than 1 milliseconds you could get better accuracy by targeting (for drawing and calibration marking) the middle of the blurs. This is interesting because as of now there is no other 3D scanner of any sort that could obtain 3d models out of fast acting scenes.
                            (sorry for going off topic in a commercial sounding way)
                            cheers
                            Ogan
                            • R
                              Roger
                              Ogan, if I dropped a garbage can of multicolored ping pong balls onto the surface it seems I would have many identifiable targets. Or perhaps dye packets.
                              I was observing a golf driving range the other day and it occurred to me that once the range was loaded with golf balls, it would be and easy surface to model. It also occurred to me that I could send a laser through a diffraction grating and instantly project registration marks onto a subject to be captured by simultaneous multiple cameras.
                              You calculation would only hold true at a 1:1 reproduction and only for motion entirely parallel to the film plane. My Pentax's top shutter speed is 1/4000. Radio signals move at light speed and electricity in a cable (any wiring distances would be extremely short) is about 2/3 the speed of light so camera synchronicity is negligible assuming the circuit is not designed with an intentional built in delay.
                              Lastly, accuracy, in LAPX's case, is less of a factor than simply capturing the essence of a typical wave shape.
                              • GarethG
                                Gareth
                                --Roger
                                I was wondering the same thing...!!
                                • oganocaliO
                                  oganocali
                                  @Roger, you are right about remote camera synchronization but the timing of the mechanical movements sometimes have variability, and some cameras need to be primed first. Grass usually has enough signal.
                                  • L
                                    lapx
                                    So, sorry guy's. This project is one on the highly confidential list and I can't share much at this time:( It's taken on different direction at this time and instead of doing a literal wave they were exploring other curvy shapes.
                                    I appreciate the efforts here which are not in vain and are helpful anycase.
                                    Thanks!
