    Venecija
    6 Posts 5 Posters 513 Views 5 Watching
      momy_21
      i want to share with you guys this render
      which i got the model from warehouse and
      add materials on it using vray.
      so, C&C are welcome
      http://img684.imageshack.us/img684/8083/uploaded.jpg
      Uploaded with ImageShack.us
      • DanielD Offline
        Daniel
        Good beginning, but could use some improvement, such as:
        1. Using different materials/textures/colors on the buildings, so they aren't identical.
        2. Adjusting the wood grain to run in teh correct direction on different elements.
        3. Better sky image.
        My avatar is an anachronism.
        • tademaT Offline
          tadema
          Hello moayed, your render looks canny but you really need to work on your textures a little more. The little things stick out to spoil a scene, the wood grain on your boats are in the wrong orientation and your bricks need scaling correctly. Small things like adding joints to the coping and giving it a over-hang will make all the difference. Please don't take this as criticism, it's not meant that way.
          regards John
            SketchUpNoobie
            Are those the wires showing in the crack on the top of the leftmost building?
            Great start though.
            SketchUpNoobie: the complete noob in all things SketchUp.
            • soloS Offline
              solo
              moayed
              There are a lot of things you could do to improve the render, how about this:
              You upload the model and folks here that have the time can render it (and do some fixes) that way you can see what they do that makes it look more realistic, and not only you but others can also learn from it.
              http://www.solos-art.com
                momy_21
                i want to thank you all for your comments
                and i'm going to share the model
                so, me & others can learn and get some improvement advises
                thank you Solo for the idea
                here is the file
                http://www.4shared.com/file/PiRaP0q_/venecija.html?
