    Bug Splat on erase!
    11 Posts 3 Posters 877 Views 3 Watching
    • voljankoV
      voljanko
      Hello.
      I want to erase some geometry before saving a model,so I use the onPreSaveModel observer to do this.
      Erasing is executed correctly,but after it the Bug Splat screen is happening.
      I would like to find a way to do it without Bug Splat screen.
      Here is the code,just select one item and it will be erased before saving the model.
      class MyModelObserver1 < Sketchup;;ModelObserver
      	def onPreSaveModel(model)
      		selection = Sketchup.active_model.selection
      		selection[0].erase!
      Sketchup.active_model.add_observer(MyModelObserver1.new)
      class MyAppObserver1 < Sketchup;;AppObserver
      	def onNewModel(model)
      	def onOpenModel(model)
      Sketchup.add_observer(MyAppObserver1.new)
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
      • Dan RathbunD
        Dan Rathbun
        http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html
        Read the Introduction section:
        Performing any edit operations of your own (such as modifying the model) inside the observer callback should be avoided, as it could cause crashes or model corruption.
        if Drawingelement#erase! causes a BugSplat!, try instead:
              selection = model.selection
              unless selection.empty?
                model.active_entities.erase_entities(selection[0])
                model.active_view.refresh()
        ... but may not work either.
        I'm not here much anymore.
        • voljankoV
          voljanko
          Uff,your solution didn't resolved the problem(same result),but helped to understand it.
          It seems that the onPreSaveModel observer is not the real pre save observer.I would need a pre-pre save observer. πŸ˜„
          • Dan RathbunD
            Dan Rathbun
            A SelectionObserver ?
            • voljankoV
              voljanko
              I have a group that is generated when a tool is activated and deleted when a tool is deactivated.
              The problem is when the model is saved when a tool is active (auto save or user save).
              I don't want that group to be saved in the model,so I have implemented the onPreSaveModel observer to delete the group.
              But I cannot get rid of the BugSplat.
              • Dan RathbunD
                Dan Rathbun
                Make sure you read (and bookmark,) these topics:
                • State of Observers β€” 28 February 2010
                • State of Observers Redux β€” 12 September 2010
                And ThomThom webpage:
                State of Google SketchUp's Observers
                (http://forums.sketchucation.com/viewtopic.php?f)":3um4efab]Other notes
                Another thing I learned was that doing modifications to the model on observer events can cause lots of problems.
                β€’If a script is doing something which trigger an event that modifies the model it will break the undo stack. I also seem that it can make SU unstable. You could potentially cause infinite loops.
                β€’After consulting with Scott it seems that queueing up a list of modifications to be done to the model and executing the list on ModelObserver.onTransactionCommit is the most reliable way to do it.
                • thomthomT
                  Mat I ask what your temp group do? What is it function?
                  (just wondering if there might be alternatives to creating temp geometry here - such as using view.draw for instance...)
                  • voljankoV
                    voljanko
                    Im using it to highlight some surfaces ,because I can draw only lines (and points and text) with view.draw.
                    Is there any samples of using the ModelObserver.onTransactionCommit and other onTransaction functions?
                    I cannot figured out what are they for.
                    • thomthomT
                      Incorrect - you can draw filled shapes with view.draw . GL_TRIANGLES, GL_TRIANGLE_STRIP,
                      GL_TRIANGLE_FAN, GL_QUADS, GL_QUAD_STRIP, GL_POLYGON will let you do that. But note that in SU prior to version 8 the fill is always black. But as of v8 it works great. You can even use transparent fill.
                      • voljankoV
                        voljanko
                        Thank you for pointing this out,I was really stacked wit this BugSplat.
                        So, more new functions to learn. πŸ€“ πŸ˜„
                        • voljankoV
                          voljanko
                          But also Dan's suggestions have positive results:
                          In the activate method of the tool I have put the
                          Sketchup.active_model.start_operation "myTool",true,true,false
                          And I have put the
                          Sketchup.active_model.abort_operation
                          in the deactivate method of the tool and in the onPreSaveModel model observer.
                          Now the group is disappear before saving the model.
                          Thank you both.
