    Model observer problem
    3 Posts 2 Posters 326 Views 2 Watching
    • voljankoV Offline
      voljanko
      I need to implement the onPreSaveModel observer,and according the http://www.thomthom.net/software/sketchup/observers/
      ,it should work in SU version 8.
      But according to my testing,the observer works only on the new model.If I close and open again the SU program,the observer is not trigged anymore.My code is simple copied from the API:
      class MyModelObserver < Sketchup;;ModelObserver
      	def onPreSaveModel(model)
      		UI.messagebox("onPreSaveModel; " + model.to_s)
       # Attach the observer.
       Sketchup.active_model.add_observer(MyModelObserver.new)
      Please somebody test it,and if confirmed,I will not touch observers anymore. 😞
      SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        Use the AppObserver to monitor for new models: http://code.google.com/intl/no/apis/sketchup/docs/ourdoc/appobserver.html
        Use the onNewModel and onOpenModel events.
        • voljankoV Offline
          voljanko
          Yes,I have thought about this right after sending my post,but want to test first.
          Now it is working ok and sorry for blaming observer for this problem.
          So this is the working code:
          class MyAppObserver < Sketchup;;AppObserver
          	def onNewModel(model)
          		UI.messagebox("onNewModel; " + model.to_s)
          		# Here is where one might attach other observers to the new model.
          	def onOpenModel(model)
          		UI.messagebox("onOpenModel; " + model.to_s)
          Sketchup.add_observer(MyAppObserver.new)
