    Vray Render (Exterior) with photomontage
    7 Posts 4 Posters 1.3k Views 4 Watching
      Scostumatu
      Hi all
      Thought id post my latest work... used Sketchup, Vray and PS.
      Was on a tight timeframe with this one.... the original site had no grass so i had to PS it in, left the sky as per the pic i took and didnt place another on in PS.
      S
      • Bryan KB Offline
        Well done! πŸ‘
        • holmes1977H Offline
          holmes1977
          Hi Mate
          Well done. Looking great. The over all lighting is great. You matched the render and photo so well.
          Where are you from.....Oz?
          Exaggeration makes a dull story better.
            Scostumatu
            @holmes1977 said:
            Hi Mate
            Thanks mate! Most of the work was done in post, pretty time consuming but was overall happy with the end result.
            Yeah from Oz, I take it ur from NZ?
            P.S - thanks again for the render material πŸ˜„
              tensai.always
              well done mate. I love your grass and trees. Really, can you tell me the grass trick? Really love to know that. well done ! πŸ˜„
                Scostumatu
                Hi Tensai
                Sure mate... grass trick is pretty easy... if you use VRAY (and obviously sketchup) then follow this tutorial and its easily done. It must be done in photoshop (or gimp)...
                http://architectural-rendering.andyorban.com/?p=127
                Theres so much you can do with vrays material ID.. What i like to do is give all my materials a material ID colour which allows me to easily select/mask it in photoshop! Oh and be sure to add MATERIAL ID in your VFB Channels in the vray options πŸ˜„
                Hope that makes sense!
                S
                  tensai.always
                  scostumatu: WOW Thanx man. really 3 years I've been using vray sketchup, never knew about this. I'm not sure how that works, but i'll give a try and let you know. Tanx man πŸ˜„
