    Artisan -> polyreduce: little strange result
    3 Posts 2 Posters 455 Views 2 Watching
      derei
      I downloaded a model from 3dwarehouse This is the model and operated Polygon Reduction from Artisan Plugin.
      At first I operated a 30% reduction and the result was good, but with significant mesh problems. I corrected it (about one hour of work) and then I ran another reduction (80%, because I lost my patience to do it in small steps) and here is the result... overall, it needs some adjustments to be ok.
      I don't know if this is the result that should be after a polyreduction, or the model is bad, or... the algorithm πŸ˜„
      Please help me with this. Thanks.
      this is the file after a 30% reduction and corrected
      second reduction (80%) and raw (I didn't touch the mesh -or should I say "mess")
      DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
        bigstick
        Wouldn't it be a whole lot easier to post your request on the Artisan forum?
          derei
          I had no idea that is one ! πŸ˜„
