    SketchupExtensions Conflicts?
    3 Posts 3 Posters 302 Views 3 Watching
    • J
      Jim
      Is it a possibility that extensions written independently by different authors inadvertently use the same Extension name? Would that mean that only the last loaded extension would be available?
      • thomthomT
        hmm... does SU use the extension.name instead of using the extension object passed?
        • Dan RathbunD
          Dan Rathbun
          Of course they can, if they choose a simple name like "Cylinder" and do not set a version string, or everyone starts out with "1.0.0".. then yes they can conflict.
          Authors should use unique names, like: "Foltz: Cylinder", and use a proper version string.
          Sketchup decides whether to load (or not to load,) extensions, based upon a concatination of the name and version string. (Check the registry and you'll see what I mean.)
          I'm not here much anymore.
