    Looping over menu item creation
    4 Posts 3 Posters 254 Views 3 Watching
    • P Offline
      pistasheos
      I'm trying to make a context menu that has several items depending on the number of attributes within dictionary, "links_dict". What I have right now works in the sense that it creates items in the submenu with differing titles, but when clicked it always passes the same information. It always takes the information from the last iteration. Is this a bug or is something I have messed up? Any help would be greatly appreciated!
      This is the specific lines of interest:
      ss = Sketchup.active_model.selection[0]
      values = ss.attribute_dictionary("link_dict").values
      for i in Range.new(values.length/2,values.length-1)
          linkmenu.add_item(%Q{Link to #{values[i]}}) { open_link(values[i-keys.length/2]) }
      A larger chunk if it helps:
      if( not file_loaded?("linktofolder2.rb") )
        UI.add_context_menu_handler do |menu|
          if( component_selected )
            sd = ss.attribute_dictionary "links_dict", true
            menu.add_separator
            linkmenu=menu.add_submenu("PWD; Links")
            if( ss.attribute_dictionary("link_dict") != nil )
                linkmenu.add_separator
              linkmenu.add_item($exStrings.GetString("Add Link")) { add_link }
        On the topic of context handlers I recommend you look at this thread I made some while ago: http://forums.sketchucation.com/viewtopic.php?f=180&t=31788
          Jim
          When using a for loop, the scope of i is outside the loop.
          Try writing the loop like this, where i is has loop scope:
          Range.new(values.length/2,values.length-1).each do |i|
          • P Offline
            pistasheos
            Thank you Jim! That did the trick! So .each method does not hold the iterator variable, but a for loop does in Ruby. Good to know.
            Thom, I'm only inspecting the first item that is selected. I'm hoping that doesn't load the entire selection set and cause delays. I'm a relatively novice programmer so I don't really know, but I don't see any studdering with the menu when I have a large selection.
