Middle Earth Castle
SketchUp -> Kerkythea -> Fotosketcher
Seriously cool.
A really nice choice of composition, particularly for the scale of a castle.
I'd love to see other views.
could I see the base of the castle and can I see or know how you went about flaring out the base?
good looking model by the way.
Thanks guys, for the comments! Unfortunately, I can't show you more views because I only modeled what was necessary to produce the scene I wanted, which is unusual for me - I'm usually obsessive about details and finishing a model, but I was anxious to move on to something new.
The castle is loosely based on a sketch by the artist Roger Dean (who is most famous for doing 70's album covers for "Yes"). To create the castle, I mostly used Push/Pull and the scaling tool to taper or flare out the sides.
I decided not to start at the bottom, or the top, but rather at the first level (the mid-section of the image) and then work downward and upward. I think that was the best idea I had, because it made it easy to see where I was going and how much room I had left for the scene I wanted.
I made a flat plane that I imagined to be a horizontal cutting plane through the castle and drew the profile outline for the front and side facade that would be visible in the render. For the back, I just squared it off. Then I sectioned off the tower nodes in the outline and made them unique groups so I could extend and scale them independently. After that, it was a matter of pulling sections down and tapering them outward to make the base, and working in the same fashion going upward and narrowing to finish it off.
I left some of the edges sharp, and smoothed others out, and made a line drawing export from SU that I used on top of the render image after I applied the watercolor processing in FotoSketcher.
I hope this info helps! Thanks again for the nice comments...
Roger Dean?! Now I see it! (I have the first edition of "Views"... if I can find it)
Anyway, good job! Looks great.
yeah that helps... thanks. and again really kool model.
I am sitting here next to my copy of Views by Roger Dean, copyright 1975 second edition and on the back is the UK price L3.95. And a companion book, The Flights of Icarus, by Donald Lehmkuhl, edited by Martyn Dean and Roger Dean- which is a collection of heroic fantasy and science fiction artists including Dean. Some of Dean's techniques were based on the premise that oil and water don't mix. Small world, small clock.
Register LoginAdvertisement
