    Class struggle
    4 Posts 2 Posters 283 Views 2 Watching
      spireup
      Im very new and struggling to access my first lot of class definitions.
      Ive scoured some online books but cant find the error. Can anyone spot the problem
      class Widget
      def initialize(xPos, yPos, zPos)
      @xPos = xPos
      @yPos = yPos
      @zPos = zPos
      myW= Widget.new(1.1,0,8)
      puts myW.inspect
      puts myW.xPos
      The inspect works fine but i cant access the attributes.
      Paul
        You haven't defined any attributes. You just define instance variables.
        <span class="syntaxdefault"><br />class Widget<br /><br />  attr_accessor</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">xPos</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">yPos</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">zPos </span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxdefault">  def initialize</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">xPos</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> yPos</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> zPos</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">xPos </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> xPos<br />    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">yPos </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> yPos<br />    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">zPos </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> zPos<br />  end<br /><br />end<br /><br />myW</span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Widget</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">1.1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">8</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">puts myW</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inspect<br />puts myW</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">xPos<br /></span>
          <span class="syntaxdefault"><br />class Foo<br />  attr_accessor</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">bar </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
          is the same as
          <span class="syntaxdefault"><br />class Foo<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Getter<br /></span><span class="syntaxdefault">  def bar<br />    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">bar<br />  end<br />&nbsp;&nbsp;</span><span class="syntaxcomment">#&nbsp;Setter<br /></span><span class="syntaxdefault">  def bar</span><span class="syntaxkeyword">=(</span><span class="syntaxdefault"> new_value </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">bar </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> new_value<br />  end<br />end<br /></span>
            spireup
            ThomThom
            thanks so much!
            Paul
