    Reloading plugins while SketchUp is running
    5 Posts 3 Posters 2.3k Views 3 Watching
      JaViXP
      @thomthom said:
      @javixp said:
      is is possible to load/unload/reload plugins with SketchUp running?
      You can load (and reload) scripts by using the Ruby Console, typing load 'myRubyFile.rb'
      I tried that and it worked. However, what I wanted was to reload plugins using... another plugin, something like this:
      def reload load 'myRubyFile.rb' end
      Problem is that one doesn't work, the Ruby Console says:
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/myRubyFile.rb;64;in `load'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/myRubyFile.rb;64;in `call'
      Note: Line 64 is where the function 'reload' is called
      "Giving up is way harder than trying"
      JaViXP's Rendering
        You must replace myRubyFile.rb with the actual filename of the plugin you want to reload. I just picked a random name...
          JaViXP
          I know, I know. I think you didn't understand me well 😳
          It does work on the ruby console, but not as a plugin itself.
          JaViXP's Rendering
          • Dan RathbunD Offline
            Dan Rathbun
            You cannot load the file itself while it's being loaded. (.. it's a circular reference.)
            The load call must be made from another file.
            I'm not here much anymore.
              JaViXP
              That fixed the 'issue', thanks πŸ‘
              JaViXP's Rendering
