    [Plugin] Solids Penetration Check
    23 Posts 7 Posters 15.7k Views 7 Watching
    • R
      richhaas
      @voljanko said:
      Yes,there is a way,why are you asking 😄
      Anyway,if you want to find the mistakes,that makes your group a non-solid,there is another plugin - Solid Inspector from thomthom.
      I don't draw with solids. Need a tool to check all the other things I draw to look for possible overlap conflicts between components, groups etc. 'Tile components' "intersecting" 'cabinet components' for instance...
      Richard
      • G
        glro
        @voljanko said:
        Please help me find the solution for this bug:
        -when one solid is a subcomponent and a subgroup in a component, the plugin can't find the penetration.
        I know the problem is in line 132 def1=solid1.entities.parent ,but don't know what to do about it.
        EDIT:SOLVED
        i cannot help you concerning the ruby programming, but i tried your plugin on the model included in your post, and it worked perfectly; event when i made a component from the component and the group
        i tried it also on the file included; components with solids inside, it worked, but in a strange way; i would like to know which are the components that interfere, but the information vanishes when the program stops...
        where are the components that intersect?
        penetration detected
        • M
          Matt666
          Aaaar it does not work with free versions... Can you do something?
          Error: #<ArgumentError: 'intersect' is a Pro only feature.>
          C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:141:in intersect' C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:141:in check_penetrations'
          C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:32:in activate' C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:159:in select_tool'
          C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:159:in `penetrationcheck'
          C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:13
          Frenglish at its best !
          My scripts
          • 2 / 2
