    [plugin]Random replacement of components
    47 Posts 13 Posters 45.0k Views 13 Watching
      AcesHigh
      It would be really nice if we could set % of random replacement.
      example:
      have a building with 300 closed window components. These will be the target
      then we also have 4 other window components that will be used as sources: totally opened window, 3/4 opened window, half opened window and 1/4 opened window
      this plugin, as it is, will replace ALL closed windows with a random number of each of the other 4 windows.
      but it would be ideal if we could decide to make random ONLY which components will be replaced, not the number.
      So...
      Original Component Remaining: 30% (I set to 30% so 30% of the 300 closed windows will remain as the "closed window" component
      Source 1 - 10% (of 300)
      Source 2 - 20%
      Source 3 - 30%
      Source 4 - 10%
      After the operation, in random locations of the building, we would have
      90 closed windows (original component)
      30 4/4 open windows
      60 3/4 open windows
      90 half open windows
      30 1/4 open windows
        Just build the source with your result % wished! πŸ˜‰
        It's not a big deal to make some copy move for build your sets of %! πŸ˜‰
        4 seconds * 16 cases = 1 minute πŸ˜„
        • sdmitchS Offline
          sdmitch
          Sorry but I don't think this method will work because the Sources are picked randomly and, other trying to avoid picking the same source back to back, there is no tracking of the number of each of the sources that have been picked.
          However, I have created a version that does if anyone else is interested.
          http://sdmitch.blogspot.com/
            If you have 50 Blue objects, 50 Pink Objects (B, P, B, P.....)
            Pick randomly in this bicolored list as Source will be very near than 50 % / 50 % of each color! πŸ˜‰
            • E Offline
              Einstein
              Hi!
              It works really nice. But if I replace many components and want to undo, I have to undo all changes one by one component. Could it be all the changes are done within one step only? Could somebody modify the script or give me a hint how to modify it? (I have no clue about coding - the only thing I can do is to replace some part of code in Notebook πŸ˜›)
              And... if it also worked with groups... that would be gorgeous.
              Anyways, great thanks for the Creators!
              • sdmitchS Offline
                sdmitch
                @einstein said:
                Hi!
                The latest version of that plugin is Component Replacement on my blog. It has a one step Undo. Sorry but it does not work with groups only components. Groups have some component characteristics but can not assign a definition to a group like you can to a component.
                  Sl-m
                  I actually tried it in Sketchup 2019.2
                  Nothing was happening at the beginning 😲 until I edit the SOURCE & TARGET "instance names" (not definition). It worked like a charm and It will make me save LOTS of time. You guys are champs! πŸ‘Š
                  Tip: you can select all your source components in one go and enter their instance name in one time.
                  Hope that helps anyone who got stuck:)
                  • 3 / 3
