    Computer paintings
    25 Posts 2 Posters 3.0k Views 2 Watching
      Inspiration Claude Monet and Vieira Da Silva
      (first is my Sketchup model and the marvelous Random Painter by Chris Fullmer , second is a table's leg's model by Felix )
      if you are interested I have made this little prog ๐Ÿ˜„
      It's for Processing(free) but you can adapt for any language ๐Ÿ˜„
      A little fractal effect thx to Benoรฎt Mandelbrot to revival the concept โ˜€
      Just put your image in the Data folder and copy past these few lines : it's all ๐Ÿ˜‰
      size(1024,512);                                  // your image's size in pixel
      PImage pilou = loadImage("your image.png");     // any image with a subject + transparent background
       int t = 8;                                    //  minimum height size in pixel
      for (int k = 8; < 513; k = k + t) {      // increase width and height
         for (int y = 0; y < 513; y = y + k) {  //position x,y of each new image on the screen
           for (int x = 0; x < 1023; x = x + k*2) {
           image(pilou,x,y,k*2,k) ;             // draw an reducted image at the x,y position on the screen
           }                                   // end loop x
        }                                     // end loop y
      filter(INVERT);                        // invert colors between each new screen, you can erase it
      t=t*2;                                // increase  height size in pixel can be anything; Da Silva t= t+8
      image(pilou,0,0);                   // draw at the end your original image ;)
      • brookefoxB Offline
        brookefox
        Pilou.... Like this?
        1. download 'Processing' http://processing.org/download/
        2. install it.
        3. a data folder will thus be created. Put your image in it and copy and paste the code also in the data folder, in a file called what? or what?
        4. run processing; load your image
        ~ Brooke
          brookefox
          Strike 1: "unexpected token:513"
          ~ Brooke
            If your orginal image has no background area transparent that will works not!
            Try with this one I lauch it now so I am sure that it's work ๐Ÿ˜„
            (click on Select all for select all the code)
            size(1024,512);
            PImage tabou = loadImage("your_image.png");
             int t = 8;
            for (int k = 8; k < 513; k = k + t) {
               image(tabou,x,y,k*2,k) ;
            filter(INVERT);
            t=t+4;
            image(tabou,0,0);
            [attachment=0:tgyb3p08]<!-- ia0 -->taboure512.png<!-- ia0 -->[/attachment:tgyb3p08]
              Must have cheekerboard on background as transparent aera!
              Hope this works!
              See you soon in four days ๐Ÿ˜‰
                brookefox
                Ah..., merci. You are right that my image had no transparent areas though it was a png, though I don't know how you could tell.
                Hopefully I'll have something to show.
                Bon voyage.
                ~ Brooke
                  brookefox
                  Still not working though with another with transparent areas. Same error. Please attach your image file so I can try it. Perhaps the png conversion by FastStone is faulty; I'll try another conversion program.
                  Didn't work with Irfan as the converter, with three different settings.. The checkerboard is how your prog is configured to display transparency; it can be balck or white or some other, I believe. I'll crank up PS for an other go.
                  ~ Brooke
                    brookefox
                    The voting is over, Pilou. No luck here.
                    ~ Brooke
                      Here an original image png (zipped) so unzipp it before any process!
                      Works for me ๐Ÿ˜„
                      If that yet don't work for you with this file, we must find another source of problem! ๐Ÿค“
                      taboure512.zip
                        brookefox
                        Alas, professor...
                        ~ Brooke
                          Seems very mysterious
                          We have the same version of Processing 1.5.1
                          Can you show me the arborescence of folders / files ( I can't see all them on the image above)
                          Normally you must have just the file "prog" and the folder "data" on the same level
                          seems they are not on the same "level" from what I can see
                          Maybe ๐Ÿ˜„
                            brookefox
                            Some little thing I have wrong... Or maybe a big thing.
                            I tried it with data next to .exe and with data in taboure512 folder. Same result.
                            ~ Brooke
                              Have you this arborescence of File / Folder ?
                              You must have the red rectangle with this little arborescence
                              anywhere : it's an entity ! Can works anywhere !
                              Here it's mixed with the arborescence of Processing : can be possible but not very clear ๐Ÿ˜„
                              If you have not maybe re-read my first post for create the first arborescence!
                              If you have yet that is some ennuyous because I don't see anything else! ๐Ÿ˜ณ
                                brookefox
                                I will reread your first post. Other than that, I am not sure what you are saying. The pic you show is my pic, so that yes is my setup. 'Arborescence' I assume means tree (directory, folder) structure.
                                My OS is Vista 64.
                                ~ Brooke
                                  Yes ๐Ÿ˜‰
                                  No !
                                  it's that you must see ๐Ÿ˜‰ (I have made a photomontage)
                                  In yours above I don't see the black icon "taboure512.pde" under the "data"
                                    If I good remember ๐Ÿ˜‰
                                    the first time launch a Processing session
                                    Copy inside the lines above
                                    Save it in a folder anywhere of your choice say "my Processing test" (name of the folder)
                                    with the name that you want say "test" (name of your prog)
                                    Surrely a message eroor because ther is not yet an image inside the data folder created
                                    QUIT
                                    You must obtain a file "test.pde" and a folder "data" both inside "my Processing test" folder
                                    (".pde" is the extension name of a Processing program normally it's given automatically)
                                    (maybe extension 's file ".pde" is not visible following your system regulates )
                                    You must have the image follow
                                    You can now put inside your image inside the "data" folder created
                                    with the same name than inside the prog : say "sketch.png"
                                    (use always PNG format : support of the transparent background)
                                    Inside the prog the "" must be writed around the sketchUp's image!
                                    PImage pilou = loadImage("sketch.png");
                                    Relaunch it by double click on the file name "test.pde" inside your folder
                                    After 3 seconds (more or less following the age of your computer: mine is ten years! )
                                    An artistic image must be created on your screen ๐Ÿ˜„
                                    Grab it and past it inside your favorite 2D prog
                                    You can modify some numeric parameters inside the prog
                                    You can change of course the name of the image inside the prog
                                    if you input an other image with another name inside the data folder!
                                    (don't change the "pilou" words except you well understand the syntax)
                                    If you don't want the "filter Invert" on your image
                                    Jut put // before
                                    //filter(INVERT);
                                    The image must have always 1024*512 inside the data folder!
                                    Hope this help you ๐Ÿ˜‰
                                      And sorry it's the second post that you must maybe re-read ๐Ÿ˜‰
                                        brookefox
                                        OK. I did not show what was beside data, only what was in data. It is beside as you advise.
                                        ~ Brooke
                                          Hum hum
                                          Last chance
                                          Copy the folder taboure512 on the Desk and run it from the Desk but I doubt
                                          Have you load and run some processing examples ?
                                          does they work ?
                                            Try to launch my own one!
                                            sketch_jun07a.zip
                                            • 1 / 2
