    Computer paintings
    25 Posts 2 Posters 3.6k Views 2 Watching
    • brookefoxB
      brookefox
      Pilou.... Like this?
      1. download 'Processing' http://processing.org/download/
      2. install it.
      3. a data folder will thus be created. Put your image in it and copy and paste the code also in the data folder, in a file called what? or what?
      4. run processing; load your image
      ~ Brooke
      • brookefoxB
        brookefox
        Strike 1: "unexpected token:513"
        ~ Brooke
          If your orginal image has no background area transparent that will works not!
          Try with this one I lauch it now so I am sure that it's work πŸ˜„
          (click on Select all for select all the code)
          size(1024,512);
          PImage tabou = loadImage("your_image.png");
           int t = 8;
          for (int k = 8; k < 513; k = k + t) {
          for (int y = 0; y < 513; y = y + k) {
            for (int x = 0; x < 1023; x = x + k*2) {
             image(tabou,x,y,k*2,k) ;
          filter(INVERT);
          t=t+4;
          image(tabou,0,0);
          [attachment=0:tgyb3p08]<!-- ia0 -->taboure512.png<!-- ia0 -->[/attachment:tgyb3p08]
            Must have cheekerboard on background as transparent aera!
            Hope this works!
            See you soon in four days πŸ˜‰
            • brookefoxB
              brookefox
              Ah..., merci. You are right that my image had no transparent areas though it was a png, though I don't know how you could tell.
              Hopefully I'll have something to show.
              Bon voyage.
              ~ Brooke
              • brookefoxB
                brookefox
                Still not working though with another with transparent areas. Same error. Please attach your image file so I can try it. Perhaps the png conversion by FastStone is faulty; I'll try another conversion program.
                Didn't work with Irfan as the converter, with three different settings.. The checkerboard is how your prog is configured to display transparency; it can be balck or white or some other, I believe. I'll crank up PS for an other go.
                ~ Brooke
                • brookefoxB
                  brookefox
                  The voting is over, Pilou. No luck here.
                  ~ Brooke
                    Here an original image png (zipped) so unzipp it before any process!
                    Works for me πŸ˜„
                    If that yet don't work for you with this file, we must find another source of problem! πŸ€“
                    taboure512.zip
                    • brookefoxB
                      brookefox
                      Alas, professor...
                      ~ Brooke
                        Seems very mysterious
                        We have the same version of Processing 1.5.1
                        Can you show me the arborescence of folders / files ( I can't see all them on the image above)
                        Normally you must have just the file "prog" and the folder "data" on the same level
                        seems they are not on the same "level" from what I can see
                        Maybe πŸ˜„
                        • brookefoxB
                          brookefox
                          Some little thing I have wrong... Or maybe a big thing.
                          I tried it with data next to .exe and with data in taboure512 folder. Same result.
                          ~ Brooke
                            Have you this arborescence of File / Folder ?
                            You must have the red rectangle with this little arborescence
                            anywhere : it's an entity ! Can works anywhere !
                            Here it's mixed with the arborescence of Processing : can be possible but not very clear πŸ˜„
                            If you have not maybe re-read my first post for create the first arborescence!
                            If you have yet that is some ennuyous because I don't see anything else! 😳
                            • brookefoxB
                              brookefox
                              I will reread your first post. Other than that, I am not sure what you are saying. The pic you show is my pic, so that yes is my setup. 'Arborescence' I assume means tree (directory, folder) structure.
                              My OS is Vista 64.
                              ~ Brooke
                                Yes πŸ˜‰
                                No !
                                it's that you must see πŸ˜‰ (I have made a photomontage)
                                In yours above I don't see the black icon "taboure512.pde" under the "data"
                                  If I good remember πŸ˜‰
                                  the first time launch a Processing session
                                  Copy inside the lines above
                                  Save it in a folder anywhere of your choice say "my Processing test" (name of the folder)
                                  with the name that you want say "test" (name of your prog)
                                  Surrely a message eroor because ther is not yet an image inside the data folder created
                                  QUIT
                                  You must obtain a file "test.pde" and a folder "data" both inside "my Processing test" folder
                                  (".pde" is the extension name of a Processing program normally it's given automatically)
                                  (maybe extension 's file ".pde" is not visible following your system regulates )
                                  You must have the image follow
                                  You can now put inside your image inside the "data" folder created
                                  with the same name than inside the prog : say "sketch.png"
                                  (use always PNG format : support of the transparent background)
                                  Inside the prog the "" must be writed around the sketchUp's image!
                                  PImage pilou = loadImage("sketch.png");
                                  Relaunch it by double click on the file name "test.pde" inside your folder
                                  After 3 seconds (more or less following the age of your computer: mine is ten years! )
                                  An artistic image must be created on your screen πŸ˜„
                                  Grab it and past it inside your favorite 2D prog
                                  You can modify some numeric parameters inside the prog
                                  You can change of course the name of the image inside the prog
                                  if you input an other image with another name inside the data folder!
                                  (don't change the "pilou" words except you well understand the syntax)
                                  If you don't want the "filter Invert" on your image
                                  Jut put // before
                                  //filter(INVERT);
                                  The image must have always 1024*512 inside the data folder!
                                  Hope this help you πŸ˜‰
                                    And sorry it's the second post that you must maybe re-read πŸ˜‰
                                    • brookefoxB
                                      brookefox
                                      OK. I did not show what was beside data, only what was in data. It is beside as you advise.
                                      ~ Brooke
                                        Hum hum
                                        Last chance
                                        Copy the folder taboure512 on the Desk and run it from the Desk but I doubt
                                        Have you load and run some processing examples ?
                                        does they work ?
                                          Try to launch my own one!
                                          sketch_jun07a.zip
                                            I use it all days πŸ˜‰
                                            Model by m-dynamics
