    โš ๏ธ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Free OpenSpace3D for Sketchup!
    12 Posts 6 Posters 4.0k Views 6 Watching
      OpenSpace3D (made by French Guys ๐Ÿ˜‰
      (Works in English too)
      MAke your own interactive World! โ˜€
      It's like Virtools but free! ๐Ÿ˜Ž
      You can make excecutable visible on any Navigators without any Knowledge of programming! ๐Ÿ‘
      A special plug for Sketchup exist for import 3D Models! ๐Ÿ˜Ž
      Have fun! ๐Ÿ˜Ž
      [flash=560,349:102pzm53]http://www.youtube.com/v/oWKvb6HOnFQ?version=3&amp[/flash:102pzm53]
      [flash=560,349:102pzm53]http://www.youtube.com/v/GOzswlcC_Ss?version=3&amp[/flash:102pzm53]
      • mitcorbM Offline
        mitcorb
        @Pilou: wow this is very interesting. Thanks for posting. ๐Ÿ‘
        • numbthumbN Offline
          numbthumb
          Great find, Pilou, thanks! ๐Ÿ‘
          Comfortably numb...
            sketchyKev
            Pilou, you are always finding the good stuff! ๐Ÿ‘
            • tridemT Offline
              tridem
              ๐Ÿ˜ฎ many thanks Pilou, that's damn interesting! can it also export the scene to be embedded in a webpage?
                You can create an "exe" standalone with your project for usb key or any support
                and of course publish your project (by FTP) on any site visible by any web navigators!
                If there is no programming or any line of code to write you must make some training ๐Ÿ˜‰
                  The Sketchup exporter is now finalised! ๐Ÿ˜Ž
                  [flash=560,349:20gnizv9]http://www.youtube.com/v/8nyYsmpcNHk?version=3[/flash:20gnizv9]
                  All your objects must be Components or groups else the alone objects will be taken
                  in only one selection with a component or group!
                  So not possibility to select something inside that!
                  For automatically grouping in separated group something floating in the 3D Space who are not component or group
                  you can use in sketchup
                  by Chris Fullmer : loose geometry to groups ๐Ÿ‘
                  For all codes following, you must write them on just one line for the Ruby Console!!!
                  This by TIG Transform a selection in components!
                  m=Sketchup.active_model;
                  m.start_operation("Faces>Compos");
                  n=m.active_entities;m.selection.to_a.each{|e|(g=n.add_group(e.all_connected);
                  g.to_component.definition.name="FaceSet#1")if e.valid? and e.parent==n.parent and e.class==Sketchup;;Face};
                  m.commit_operation
                  http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=15209;image
                  If you want all faces selected in components: past this in the ruby console by TIG
                  m.selection.to_a.each{|e|(g=n.add_group(e);
                  g.to_component.definition.name="Face#1")if e.class==Sketchup;;Face}
                  http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=15210;image
                  If you want all all faces of a selection become groups
                  (except existing groups or composants)
                  m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face}
                  http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=15211;image
                  Have fun! ๐Ÿ˜Ž
                    [flash=560,349:2mmwgziz]http://www.youtube.com/v/D63n1uozWrU[/flash:2mmwgziz]
                    [flash=560,349:2mmwgziz]http://www.youtube.com/v/aYfP6xRlpeE[/flash:2mmwgziz]
                      Ps For the Net visitor must load the Scol "Viewer" if it's not existing in it's navigator ๐Ÿ˜‰
                        A little video : export Sketchup to OpenSpace3D + Dynamic Component simulation ๐Ÿ˜‰
                        Sorry ๐Ÿ˜ณ it's in French but it's visual ๐Ÿ˜‰
                          ChrisWMan
                          Can you make working doors etc?
                            you can't modelize nothing inside
                            but you can modify Size or copy past something existing ๐Ÿ˜„
                            Of course you can make "rotating" "sliding" doors etc...
