    Select Visible geometry
    5 Posts 2 Posters 846 Views 2 Watching
    • Al HartA Offline
      Al Hart
      OK - here is Al again, trying to see if someone has already written something before we try to write it.
      A client asks:
      Is there a way for sketch-up to only process what is visible
      I explained:
      We don't have anything like that yet.
      We have avoided it, because sometimes "invisible" items are included in reflections or shadows, lighting, or might add indirect, lighting.
      Also, by "invisible", we would mean - not visible on the screen in wire frame mode - we would not mean "behind a wall", behind glass, in a recessed ceiling, etc."
      Still, it might be a nice feature. Does anyone have a ruby which selects or identifies visible, (top level), geometry only that he could use to select "visible" items, (and then use our "process selected items only" features?
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • honoluludesktopH Offline
        honoluludesktop
        Al, There is a snippet developed and posted here by Chris F. that scans the SketchUp window one pixel at a time, and identifies the face at that location. Not 100% accurate, but perhaps you can start with that?
        • Al HartA Offline
          Al Hart
          Ah I wish I had that elusive link to Chris's script or the thread that mentions it.
          I tried searching for "one pixel" and for "invisible" but I didn't find it.
          http://t1.gstatic.com/images?q=tbn;ANd9GcS57HjLrDqZ7AmiY5ko_2gH_1nNUBPodM-IGmtCOXfIZqPVlUOktg
          Al Hart
          • Al HartA Offline
            Al Hart
            Thanks for the idea. This is probably what the client really wanted - only those faces which we actually visible on the screen.
            I was looking for the opposite - the components or other geometry whose bounding box contains, or intersects the screen.
            Both might be handy
            Al Hart
              honoluludesktop
              If locating the faces is sufficient, you can start with my code here. Just noticed that there is a link to Chris's post too.
