    Notepad++ and SketchUp Bridge in SU8
    8 Posts 5 Posters 2.2k Views 5 Watching
    • H
      Heven7_floor
      I am looking for method to bridge SU8 with notepad++, and I see this article , might I ask anyone that how notepad++ can run code by TBD 's bridge, because I use well as ever in SU7(free) ,but it can't work in SU8(free) 😞
      Thank you
      • dereiD
        derei
        Thank you
        Is possible, check this post: http://forums.sketchucation.com/viewtopic.php?f=169&t=6903#p137855
        DESIGNER AND ARTIST DEREI.UK
        • H
          Heven7_floor
          Thank you
          thanks dereeei
          but I am already use TBD's bridge on SU8 as link by the same method like to SU7, but it 's not happen on SU8 , I doubt which I might missed something that should be adapte from this way to SU8 😐
          • tbdT
            tbd
            Heven7_floor: define doesn't work. what do you expect and what is the outcome ?
            SketchUp Ruby Consultant | Podium 1.x developer
            http://plugins.ro
            • Dan RathbunD
              Dan Rathbun
              I actually have the bridge files installed in a common dir:
              %(#000000)[C:\Program Files\Google\TBD\SU_Bridge]
              .. and then I put a bridge_ext.rb file in each Plugin dir of the SU versions, that loads the files from the common dir.
              That way SUB.EXE is always in the same place, and you do not need to change the path to it within Notepad++ regardless of whatever version of Sketchup is loaded.
              bridge_ext.rb
              I'm not here much anymore.
              • thomthomT
                I split these posts off to a separate thread - just to untangle the conversation.
                • H
                  Heven7_floor
                  Thanks very much thom ,you lead me to solving πŸ‘ πŸ‘ πŸ‘
                  • H
                    Heven7_floor
                    [attachment=0:1pazsmqa]<!-- ia0 -->bridge_ext.rb<!-- ia0 -->[/attachment:1pazsmqa]
                    This is excellent way, and it 's greatness solution ,thanks for your kindly help πŸ‘ πŸ‘
