    Artisan to proxy
    Scheduled Pinned Locked Moved Organic Modelling
    3 Posts 2 Posters 8.6k Views 2 Watching
      deanlegg
      How do you return to the proxy after you have done a SDS?
      I can do it straight away by clicking the back button , but after a few more ops I can't
      Please help
      Cheers Dean
      • soloS Offline
        solo
        Artisan is more than just a plugin, it's a work-flow. What I mean is that when using Artisan you need the change the way you normally work with SU.
        Firstly disable auto-save, as you are going to need to save manually and because auto-save interrupts SU IMO.
        Now before using any plugin always hit the save, that way you can revert or reopen in case of hanging or bug splats.
        I use the back button all the time to test my proxy's, divide and back, make changes, divide and back, when I am happy with my proxy I save it in a folder (project folder) then carry on with next part, I assemble all in end and do final subdivisioning.
        http://www.solos-art.com
          deanlegg
          Ah ha
          That makes a lot of sense
          Thanks for the quick reply Pete
