    Tracking changes of component definitions with observers
    9 Posts 4 Posters 760 Views 4 Watching
    • OricAtmosO Offline
      OricAtmos
      Hey,
      I'm trying to track changes of the model with observers. An EntitiesObserver added to active_model lets me see when faces are created outside any component. What do I have to do to see changes inside components? What I tried to do is add an EntitiesObserver to the entities object of each newly created ComponentDefinition but it doesn't seem to work.
      Thanks,
      Ralf
      • Dan RathbunD Offline
        Dan Rathbun
        Attach an EntitiesObserver subclass to the Definition's entities object (just as you did the model's entities object.)
        some_defn.entities.add_observer( defn_watcher_by_oric )
        You can also attach a custom subclass of EntityObserver to the ComponentDefinition objects themselves ??
        I'm not here much anymore.
          Dan Rathbun
          OK.. I see you tried that (my previous post was the first of the morning. "yawn")
          IF you are doing this inside a method, it's possible the references are being Garbage Collected.
          You can try (and I am assuming you wrap your code inside a module,) to use module var references for both the definition entities collection objects and the custom observer instance.
          module Oric
            @@my_ents_spy = MyDefnEntitiesObserver.new()
            @@watched_comp_ents = [] # a blank array
            def self.attach_spies()
              Sketchup.active_model.defintions.each {|defn|
                ents = defn.entities
                unless @@watched_comp_ents.include?( ents )
                  success = ents.add_observer( @@my_ents_spy )
                  if success
                    @@watched_comp_ents << ents
                  else
                    puts("Error attaching observer to #{defn.inspect} entities collection; #{ents.inspect}")
            # module init
            unless file_loaded?(__FILE__)
              self.attach_spies()
              file_loaded(__FILE__)
            OricAtmos
            I think it's got something to do with the references. Inside my DefinitionsObserver class I was using an instance variable to hold a reference to my EntitiesObserver like this:
            # class definition inside module AC3D_Raven_Exporter
            class DefinitionsObserver < Sketchup;;DefinitionsObserver
                @entities_observer = AC3D_Raven_Exporter;;EntitiesObserver.new
                def onComponentAdded(definitions, definition)
                    definition.entities.add_observer(@entities_observer)
            This didn't work (I think I should have used the method initialize). It works if I change it to a class variable. It also works if I just create a new EntitiesObserver every time I need to add one. But that's a waste of resources.
            Thanks for the help!
              Yes you do. Your variable was defined in the wrong scope.
                OricAtmos
                Where exactly did the variable end up anyway? did it exist only while the class definition was read from the file and executed?
                  I got defined as a class level instance variable.
                  Here's a breakdown if the scopes: http://railstips.org/blog/archives/2006/11/18/class-and-instance-variables-in-ruby/
                  • AdamBA Offline
                    AdamB
                    FWIW,
                    you may want this as a singleton that is shared amongst all instances (as you've almost written by mistake).
                    "class instance variables" is definitely a double-take. 😲
                    Adam
                      Dan Rathbun
                      Like so:
                          @@entities_observer = nil # ref to the singleton instance
                          attr_reader( ;entities_observer )
                          def initialize()
                            if @@entities_observer.nil? # ref'ing the class ref
                              @@entities_observer = AC3D_Raven_Exporter;;EntitiesObserver.new()
                            # otherwise the instance to the observer is valid and just reuse it.
                            @entities_observer = @@entities_observer
                      ADD: and you can do the same thing 1 level up (in your custom AppOserver,) by creating a singleton instance of the DefinitionsObserver, and attaching it to all the component definitions that you wish to "watch".
                      I usually also write a detach_from() method, that uses an array or hash of "watched" items, in order to detach observers when I no longer need to watch them.
