    Attribute data size limit?
    6 Posts 4 Posters 410 Views 4 Watching
      Has anyone encountered size limitation in regards to how much data one can store in an attribute?
      I haven't noticed any - but I just wanted to check to be sure.
      • Didier BurD Offline
        Didier Bur
        Hi TT,
        The 'largest' attribute I had to store was a marshalled object of about 100Kb and this caused no problem.
        How big did you try ?
        DB
        • AdamBA Offline
          AdamB
          LightUp stores all your normalmaps as compressed attributes and I ran into this limit.
          By trial and error, I settled on 750000 as being a safe upper limit. ie LightUp chunks your data into blocks of 750000.
          Adam
          • Dan RathbunD Offline
            Dan Rathbun
            Any difference in the limit using Ruby v1.8.6-p287 on Win32, as opposed to the obsolete v1.8.0 under SU 7.x ?
            I'm not here much anymore.
              @didier bur said:
              Hi TT,
              You managed to marshal objects into attributes? I just got data loss when I tried that:
              http://forums.sketchucation.com/viewtopic.php?f=180&t=36448
                Didier Bur
                Hi TT,
                I was speaking of an own object type (array of parameters for instance), not SU entities or objects.
                DB
