    New Hardware Speed Test & how to really speed it up!
    11 Posts 5 Posters 2.1k Views 5 Watching
    • S
      sketchyKev
      I have found that switching on the OpenGL Hardware Acceleration option speeds up the real time speed of SU by up to 6 times! I am not sure if all systems can take advantage of this and thought it would be interesting to have this test so that we can find out what is the best system for running SU on.
      To run the test, download this model from the Sketchup Warehouse:
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      and you do not already have SketchPhysics installed you will need to download the latest version from here:
      http://code.google.com/p/sketchyphysics/downloads/list
      and install it to your Program Files/Google/Google SketchUp 8/Plugins folder.
      To carry out a timed run, open the "Ruby Console" in the "Window" menu. Start the simulation running using the "play" button and let it run for about 60 frames (displayed at bottom left) and stop the simulation. The average frames per second will be shown in the ruby console. Turn shadows on and off in the "View" menu and turn hardware acceleration on and off in the "Window/Preferences/OpenGL" menu. Mine seams to be have been off by default and I am wondering how many other people have missed this easy way to speed their system up?
      My Test Results with Shadows "ON"
      Hardware Acceleration "OFF" 1.37 fps (Shadows not actually displayed)
      Hardware Acceleration "ON" 8.14 fps (Nearly 6X faster) (Shadows displayed)
      This is my PC system spec:
      Processor AMD Athlon(tm) II X4 620 Processor 2.6 GHz
      System
      Manufacturer MEDIONPC
      Model MS-7646
      Total amount of system memory 3.00 GB RAM
      System type 32-bit operating system
      Number of processor cores 4
      64-bit capable Yes
      Storage
      Total size of hard disk(s) 466 GB
      Disk partition (C:) 438 GB Free (466 GB Total)
      Media drive (D:) CD/DVD
      Graphics
      Display adapter type ATI Radeon HD 4200
      Total available graphics memory 1407 MB
      Dedicated graphics memory 256 MB
      Dedicated system memory 0 MB
      Shared system memory 1151 MB
      Display adapter driver version 8.821.0.0
      Primary monitor resolution 1920x1080
      DirectX version DirectX 10
      All the information in the box above is basically copy and pasted from system information in the Windows Control Panel. (See my 3rd post in this thread for how to do this.) Just manually add your software details:
      Software
      WIndows 7 Home Premium - Service Pack 1 - 32 Bit
      Sketchup Ver 8.0.4811
      SketchyPhysics Ver 3.2
      P.S. I ran my test with the Sketchup window maximised to full-screen. To be consistent please do the same. I have found that with SU running in a quarter sized window it runs twice as fast as full-screen mode.
      • mitcorbM
        mitcorb
        Hi, sketchyKev:
        I notice your Display Adapter says nothing of OpenGL support, only DirectX. I am also given to understand that ATI cards are not necessarily first choice for Sketchup? However, I have also heard that lately the top graphics card producers have been working toward double compliance? (both OpenGL and DirectX).
        Can anyone clarify this confusion?
        • S
          sketchyKev
          @mitcorb said:
          Hi, sketchyKev:
          Hi Mitcorb,
          I had heard similar things, but the test proves my ATI card really does benefit from selecting "OpenGL hardware acceleration". It may be that the latest SU supports Direct X hardware acceleration as well (just guessing). My PC is fairly modern, but "bargain basement" with the greatest savings probably being made in the graphics card department and is the weakest link in the system. I am thinking of getting a better card, so I am hoping people will post some test results here so that we can can find out what systems really motor along and what systems to avoid. The proof is in the pudding, so get testing and please share!
          Another myth in an older speed test thread is that SU does not take advantage of more than one core processor. These screenshots of the performance monitor in Windows Task Manager shows that Sketchup 8 is using at least two cores when the simulation is running:
          • D
            dsarchs
            About the AMD (no longer ATI) issue: I've been using an HD6950 for several months and haven't noticed any issues with sketchup. I haven't run any tests to objectively say how fast it runs, but it's much quicker than my Nvidia 9800GT at work -- part of that is due to the processor, though (core 2 quad @ 2.66 ---> i5-2500k @ 3.7).
            The point is, no problems with new AMD.
            Knowledge is a polite word for dead but not buried imagination.
            -e.e.cummings
            • S
              sketchyKev
              Here is how to easily find and copy and paste your system information in Windows 7.
              (It took me while to figure it out 😒 )
              If all that seems too much trouble or accessing your operating system details is different, just manually post the basic details such as:
              CPU model & speed:
              No of cores:
              Amount of memory:
              OS & SU version:
              Graphics Card model:
              That would still be very useful. 😄
              • H
                hpnisse
                Hello!!
                I did the test as you described. And the result was the following:
                OpenGL ON
                Shadow off: ["Time", 2.377, "Frames", 64, "Fps", 26.9246949936895]
                Shadow on: ["Time", 5.117, "Frames", 65, "Fps", 12.702755520813]
                OpenGL OFF
                Shadow off: ["Time", 28.666, "Frames", 65, "Fps", 2.26749459289751]
                Shadow on: ["Time", 30.419, "Frames", 65, "Fps", 2.13682238074887]
                The difference is incredible. But OpenGL was active from the beginning, so I've never had that problem.
                The computer specs:
                Processor Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
                Minne (RAM) 4,00 GB 7,5
                Grafik Radeon HD 6800 Series 7,8
                Spelgrafik 2807 MB tillgÀngligt grafikminne 7,8
                PrimÀr hÄrddisk 123GB ledigt (243GB totalt) 5,9
                Windows 7 Ultimate
                System
                Tillverkare Gigabyte Technology Co., Ltd.
                Modell PH67A-UD3
                Total mÀngd systemminne 4,00 GB RAM
                Systemtyp 64-bitars operativsystem
                Antal processorkÀrnor 4
                Lagring (Storage)
                Total mÀngd hÄrddiskutrymme 1081 GB
                Diskpartition (C:) 123 GB ledigt (243 GB totalt)
                Diskpartition (D:) 61 MB ledigt (100 MB totalt)
                Diskpartition (E:) 29 GB ledigt (29 GB totalt)
                Diskpartition (F:) 52 GB ledigt (492 GB totalt)
                Diskpartition (G:) 29 GB ledigt (30 GB totalt)
                Diskpartition (H:) 2 MB ledigt (2 MB totalt)
                Diskpartition (I:) 149 GB ledigt (196 GB totalt)
                Medieenhet (J:) CD/DVD
                Diskpartition (K:) 11 GB ledigt (90 GB totalt)
                Medieenhet (P:) CD/DVD
                Medieenhet (Q:) CD/DVD
                Medieenhet (R:) CD/DVD
                Medieenhet (S:) CD/DVD
                Medieenhet (T:) CD/DVD
                Grafik
                Typ av grafikkort Radeon HD 6800 Series
                Total mÀngd tillgÀngligt grafikminne 2807 MB
                Dedikerat grafikminne 1024 MB
                Dedikerat systemminne 0 MB
                Delat systemminne 1783 MB
                Grafikkortets drivrutinsversion 8.782.0.0
                PrimÀr bildskÀrmsupplösning 1920x1080
                DirectX-version DirectX 10
                Everything is copied straight across, so most are in Swedish, but I think is enough to understand anyway.
                Windows and Sketchup version is in the signature
                ** %(#BF0000)[/hpnisse]**
                %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
                • S
                  sketchyKev
                  @hpnisse said:
                  Hello!!
                  OpenGL ON
                  OpenGL OFF
                  Hi Hpnisse,
                  Thanks for getting the ball rolling. Very community spirited of you! 😄
                  Your results are 50% faster than my system, but your system is obviously better, in fact I would have thought it would be even faster at a glance. I am curious why in another speed thread there was orders of magnitude differences in performance between systems, with some systems doing less than 2 fps and one mac achieving 120 fps! đŸ˜Č Hopefully we will get some more test results here and see what is going on.
                  Thanks again!
                  Kev.
                  • H
                    hpnisse
                    I did the test today, but today I had no other programs running in the background.
                    So the result was the following:
                    [list:2z3c5kg9]OpenGL ON
                    Shadow on: ["Time", 3.912, "Frames", 60, "Fps", 15.3374233128834]
                    Shadow off: ["Time", 1.054, "Frames", 60, "Fps", 56.9259962049336]
                    OpenGL OFF
                    Shadow on: ["Time", 60.347, "Frames", 60, "Fps", 0.994249921288548]
                    Shadow off: ["Time", 24.993, "Frames", 60, "Fps", 2.4006721882127][/list⭕2z3c5kg9]
                    I even tried to hide the edges, but it made ​​minimal difference.
                    In order to get exactly 60 frames, I used LazyScript and "endSim ()" command.
                    • S
                      sketchyKev
                      [list:n7i7csve]OpenGL ON
                      OpenGL OFF
                      Shadow off: ["Time", 24.993, "Frames", 60, "Fps", 2.4006721882127][/list⭕n7i7csve]
                      Hi Hpnisse,
                      That is more like what I thought your system would be capable of, you are really motoring now! You got nearly 57 fps with shadows off and I can only manage 18 fps with shadows off and no programs running in the background 😞
                      Thanks for your contributions! 😄
                      • R
                        rhots
                        Sketchykev, these are my specs....Windows 7 32bit, intel core duo E7500 @ 2.93, Nvidea QuadroFX 380 LP
                        Rick
                        • S
                          sketchyKev
                          This is a quick summary of the results so far (all with hardware acceleration turned on). Thanks all 😄
                          Operating System, CPU @ GHz, Cores, Graphics card, Shadows ON / Shadows OFF
                          WIndows 7 32 bit, AMD Athlon II X4 620 @ 2.60 GHz, 4 core, ATI Radeon HD 4200, 8 fps / 19 fps
                          Windows 7 32 bit, Intel Core duo E7500 @ 2.93 Ghz, 4 core, Nvidea QuadroFX 380 LP, 22 fps / 34 fps
                          Windows 7 64 bit, Intel Core i5-2500K @ 3.30 Ghz, 2 core, Radeon HD 6800 Series , 15 fps / 57 fps
                          So far, all the listed cards benefit (in the region of an order of magnitude faster) from having OpenGL hardware acceleration enabled.
