    (Request) Perspective 360 rotate
    4 Posts 4 Posters 670 Views 4 Watching
    • Z Offline
      Zeak
      Hi all I have been using sketchup for a while now to make mods for Chris Sawyers Locomotion. I have been looking for plugins for a while to assist me rather then moving the camera manually and taking an image. What I am after is tool that centres the axis in the middle of the modle. If possible once the distance is set to rotate the modle 360* (Aprox 5.625* at a time to create 64images). Is this possible in any way or has been done before. Any help would be greatly appreciated.
      • mitcorbM Offline
        mitcorb
        Hi, Zeak:
        As a first step, may I suggest you look in the Plugins Index--red button link at top of this page. Do a keyword search on camera, animation, scenes. I have seen discussion related to your question in this forum. Unfortunately, I do not have time right now to check on links.
        • K Offline
          kyyu
          I saw this plugin recently on the forum. Actually, someone was having a problem and discussing it. It seems like what you want, rotating and exporting the image:
          SketchUp Web Exporter Beta
          http://www.youtube.com/watch?v=j0Tmlko5YTU
          You can download it here:
          http://sketchup.google.com/download/plugins.html
            driven
            hi
            I use a modified version of create360veiw.rb http://forums.sketchucation.com/viewtopic.php?p=45473#p45473
            I've modified it create 36 scenes plus 36 layers so you can then link up other stuff on layers.
            try it out, if it's basically useful and If you can't do the mods yourself, PM me and I'll send a copy of mine set for 64.
            I then export as animation to give me jpegs etc... but that might be a Mac thing.
            john
