    [Request] Report current Aspect Ratio
    3 Posts 2 Posters 409 Views 2 Watching
    • JClementsJ Offline
      JClements
      Advanced Camera tools will show a numerical value for a camera with a user defined aspect ratio. However, if the user does not input an aspect ration, Advance Camera tools reports "screen".
      Can a script be written that to simply reports a message box or a text label with the aspect ratio of the current screen?
      John
      • Didier BurD Offline
        Didier Bur
        Hi John,
        When not set, the aspect ratio is reported zero.
        Here is a script that reports the AR when not zero, and report the viewport ratio when the AR is zero.
        Unzip in Plugins folder, restart SU, select "Report Aspect Ratio" in the "Camera" menu.
        Hope this helps.
        Cam_ar.zip
        DB
          JClements
          Thank you, Didier. Merci beaucoup.
          Regards, John
