    Auntie Em Auntie Em!
    44 Posts 18 Posters 1.9k Views 18 Watching
    • jeff hammondJ Offline
      jeff hammond
      Terrifying! 😲
      Just a question: there is no Nuclear Plants on the path of all theses new tornadoes?
      probably but i highly doubt a tornado -- even an f5 -- is going to take out a nuclear plant.
      most buildings damaged in tornados are wooden framed (you don't see much crumbled brick houses in wind disaster pics 😉 )
      dotdotdot
      • mitcorbM Offline
        mitcorb
        Poorly reinforced brick veneer will peel away like paper. Some years ago, straight line winds came through and sucked the brick veneer off a local radio station. Two stories tall, pre-engineered metal building. The brick was on the leeward side of the building. Though I never went any closer than the street, the fact that the brick layer was still mostly intact as one plane on the ground told me that the dumbass who installed it did not use brick ties of any sort. The collapse narrowly missed their main satellite dish mounted on the ground next to the building.
        • boofredlayB Offline
          boofredlay
          The Browns Ferry Nuclear plant will most likely be offline for a couple weeks.
          "The systems at Browns Ferry did exactly what they were supposed to. This is not comparable to Fukushima because it wasn't the result of damage to the plant, rather the lines leaving the plant were cut," said Scott Brooks, spokesman at the U.S. Nuclear Regulatory Commission (NRC).
          When Browns Ferry lost offsite power, the reactors automatically shut and emergency backup diesel generators kicked in to cool the nuclear fuel.
          Per Yahoo news.
          http://news.yahoo.com/s/nm/20110428/us_nm/us_utilities_operations_tva_browns_6
            jeff hammond
            yeah, but, at least he saved a $ coupla_hundred
            dotdotdot
            • 3 / 3
