    Making scenes
    3 Posts 3 Posters 978 Views 3 Watching
      beltloaderman
      I have another question. I wanted to make scenes that had my hall table come apart in different section. what mean by that is, in one scene have the top of the table lifted up. In the second scene, the leg pulled off to the side. Each scene would have a different part of the hall table come apart until the table was completely exploded. Then, reverse the scenes until the table is back together again. It would like making a movie. I tried a couple of things, but no luck.
      Thanks for any help.
        This will probably help you. The process is essentially the same for what you want to do.
        In a nutshell:
        Make copies of the parts and move them to their exploded view locations. If you want to create the appearance of motion, place intermediate copies as well.
        Make different layer associations for each copy of the part.
        Turn off all unneeded layers for scene one. This will hide all the component copies you don't want to see.
        Create a scene.
        Turn on the next layer(s) and turn off the ones you don't need.
        Create a scene.
        Repeat until you've got it all covered.
        • HumpmetwiceH Offline
          Humpmetwice
          Try these.
          http://forums.sketchucation.com/viewtopic.php?t=17459
          http://forums.sketchucation.com/viewtopic.php?t=10946
          http://forums.sketchucation.com/viewtopic.php?t=33417
