    How to insert a component instance from a definition.
    6 Posts 2 Posters 592 Views 2 Watching
    • honoluludesktopH
      honoluludesktop
      If the model has a component definition (no instance), is there a way to insert an instance of that definition via the api?
      • thomthomT
        Entities.add_instance
        http://code.google.com/intl/no/apis/sketchup/docs/ourdoc/entities.html#add_instance
        • honoluludesktopH
          honoluludesktop
          There is no instance of the component in the model, only the definition.
          • honoluludesktopH
            honoluludesktop
            Its like when you open the Windows > Component's window and you see instances that have been previously deleted, but can still be inserted into the model.
            • thomthomT
              Yes? Entities.add_instance is what you use then.
              model = Sketchup.active_model definition = model.definition[0] # getting a reference to a ComponentDefinition tr = Geom::Transformation.new model.entities.add_instance( definition, tr )
              • honoluludesktopH
                honoluludesktop
                OK, thanks. I must have done it wrong, when I tried to use entities.add_instance previously. I will work on it tomorrow.
