    Good way to test a script
    8 Posts 6 Posters 992 Views 6 Watching
    • liquid98L
      liquid98
      Hello,
      I'm stupid I know, but what do you guys do to test a script that you've wrote?
      My method gets me on my nerves by now. It goes like this:
      1 write a ruby script, and save it in the plug-ins folder
      2 open sketchup
      3 take notice of error message
      4 close sketchup
      5 modify script
      6 goto step 2 until script works.
      There must be a more comfortable way to test a ruby script??
      please help
      edit:
      Found a solution myself:
      http://www.johnj.com/drawing/sketchup/ruby-plugins-for-sketchup/
      edit: But it doesn't work for me, can anyone please help?
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
      • thomthomT
        I just reload the script by using the Ruby Console:
        load 'filename.rb'
        • K
          kyyu
          I use Jim Foltz's Ruby Toolbar plugin. It will load and reload a plugin file: http://forums.sketchucation.com/viewtopic.php?t=1542
          That plugin in the 1st post looks interesting, but looks like it checks a folder every second, as long as sketchup is running. Do you really want that?
          -Kwok
          • Dan RathbunD
            Dan Rathbun
            Put your scripts in a subfolder of the Plugins folder, call it "Dev" or "Liquid" or whatever, and that reloader should work better (you really do not want to reload all scripts in the "Plugins" folder.)
            The reloader can be tweeked to reload upon a larger interval (rather than 1 sec.)
            I'm not here much anymore.
            • honoluludesktopH
              honoluludesktop
              tt's way works OK for me. One less plugin, and when debugging, the ruby console is open anyway. btw, I use web console too.
              • liquid98L
                liquid98
                Thanks guys for the input!
                • PixeroP
                  Pixero
                  Here's a topic I started with some good info about debugging scripts:
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=34052
                  • liquid98L
                    liquid98
                    That's a really useful thread indeed, thnx πŸ˜„
