[Plugin] VisTools
Issue: Toolbar button ordinal positions
ADD: Issue filed for milestone 1.3.1, and fix has been done.
UPDATE v1.3.1
Pushed update into a forked GitHub online repository at:
https://github.com/DanRathbun/sketchup-vistools
Feedback via: https://github.com/DanRathbun/sketchup-vistools/issues
Hi ishboo, the plugin is great but unfortunately "isolate selected layers", "isolate selected entities" and "freeze" and "unfreeze" does work."Hide selected layers" and "show all layers and entities" work perfectly. I formerly used the hide tool within the SCF selector toolbar but unfortunately this toolbar is not available fro SU 2014. I work with SU 2014. Can you help?
This has not been tested under SU2013 nor SU2014.
WHAT commands DO NOT work ????
@dan rathbun said:
UPDATE v1.3.3
Added Asian language support:
Chinese Simplified (zh-CN) language support by Xiao Long (guanjin)
Other Asian language support files (preliminary):
Chinese Traditional (zh-TW)
Japanese (ja)
Korean (ko)
THANK YOU to :
- Xiao Long (guanjin)
Chinese Simplified (zh-CN) language file.
what, I didn't know you speak korean Dan.
I don't mind helping out the language review, but I want to avoid installing another version of SketchUp in Korean
I don't. I used Google Translator and Bing Translator. I have no idea if my translations are cussing a ppl, or not.
@josephkim626 said:
I don't mind helping out the language review, but I want to avoid installing another version of SketchUp in Korean.
You can load the files in a code editor.
I use Notepad++ on Windows.
The files must be saved in UTF-8 encoding.The Vistools loader ruby in the "Plugins" folder has the descriptions in it, and the korean setting is this:
@@plugin.description = %q{VisTools:(๋น์  ๋๊ตฌ) ๋ช ๊ฐ์ง ์ ์ฉํ ์ํฐํฐ๋ฅผ ์ถ๊ฐ ํ ๊ณ ํ์ ๋๊ตฌ์ Sketchup ์์ ๋ ์ด์ด: ์จ๊ธฐ๊ธฐ, ํ์, ๋๊ฒฐ ๋ฐ ํด ๋}In the plugins' folder is a "
VisTools_ko.rb" file with the other UI strings which looks like:# encoding; UTF-8 # # THIS FILE MUST BE SAVED IN ENCODING; "UTF-8 WITHOUT BOM" # module IntrepidBear # <--<< Dana Woodman's proprietary toplevel namespace module VisTools # <--<< THIS plugin's nested namespace #{# MODULE VARIABLE LANGUAGE HASHES # # --==== KOREAN ====-- # @@menutext = Hash[ ;plugin_name, "๋น์  ๋๊ตฌ", # ;hide_layers, "๋ ์ด์ด ์จ๊ธฐ๊ธฐ", ;isolate_layers, "๋ถ๋ฆฌ ๋ ์ด์ด", ;hide_entities, "์ํฐํฐ ์จ๊ธฐ๊ธฐ", ;isolate_entities, "์ํฐํฐ๋ฅผ ๋ถ๋ฆฌ", ;freeze_entities, "๊ณ ์  ๊ทธ๋ฃน ๋ฐ ๊ตฌ์ฑ ์์", ;unfreeze_all, "๊ณ ์  ์ทจ์ ๋ชจ๋", ;show_all, "๋ชจ๋ ํ์", # ;debug_mode, "๋๋ฒ๊ทธ ๋ชจ๋" ] @@tooltips = Hash[ ;hide_layers, "์ ํํ ๋ ์ด์ด ์จ๊ธฐ๊ธฐ", ;isolate_layers, "์ ํ ๋ ๋๋ฉด์ธต ๋ถ๋ฆฌ", ;hide_entities, "์ ํํ ์ํฐํฐ ์จ๊ธฐ๊ธฐ", ;isolate_entities, "์ ํ ๋ ์ํฐํฐ๊ฐ ๋ถ๋ฆฌ", ;freeze_entities, "๊ทธ๋ฃน ๋ฐ ๊ตฌ์ฑ ์์ ๋๊ฒฐ", ;unfreeze_all, "๋ชจ๋ ๊ณ ์  ์ทจ์", ;show_all, "๋ชจ๋ ๋ ์ด์ด ๋ฐ ์ํฐํฐ ๋ณด๊ธฐ" ] # #}# end # module VisTools end # module IntrepidBear -
@@plugin.description = %q{VisTools:(VisTools) ์ค์ผ์น์ ์ ๋ ์ด์ด์ ๊ฐ์ฒด ์ ์ด๋ฅผ ๋๋ ์จ๊ธฐ๊ธฐ, ํ์, ๋๊ฒฐ ๋ฐ ํด๋ ๋ฑ์ ๊ธฐ๋ฅ์ ์ถ๊ฐ.}@@menutext = Hash[
:plugin_name, "Vistools",
:hide_layers, "๋ ์ด์ด ์จ๊น",
:isolate_layers, "๋ ์ด์ด ๋ถ๋ฆฌ",
:hide_entities, "๊ฐ์ฒด ์จ๊น",
:isolate_entities, "๊ฐ์ฒด ๋ถ๋ฆฌ",
:freeze_entities, "๊ฐ์ฒด ๋๊ฒฐ",
:unfreeze_all, "๋ชจ๋ ๋ ์ด์ด ๋ฐ ๊ฐ์ฒด ํด๋",
:show_all, "๋ชจ๋ ๋ ์ด์ด ๋ฐ ๊ฐ์ฒด ํ์",
:debug_mode, "๋๋ฒ๊ทธ ๋ชจ๋"
]@@tooltips = Hash[ :hide_layers, "์ ํ ๋ ๋ ์ด์ด ์จ๊ธฐ๊ธฐ", :isolate_layers, "์ ํ ๋ ๋ ์ด์ด ๋ถ๋ฆฌ", :hide_entities, "์ ํ ๋ ๊ฐ์ฒด ์จ๊น", :isolate_entities, "์ ํ ๋ ๊ฐ์ฒด ๋ถ๋ฆฌ", :freeze_entities, "์ ํ ๋ ๊ฐ์ฒด ๋๊ฒฐ", :unfreeze_all, "๋ชจ๋ ๋ ์ด์ด ๋ฐ ๊ฐ์ฒด ํด๋", :show_all, "๋ชจ๋ ๋ ์ด์ด ๋ฐ ๊ฐ์ฒด ํ์" ] # #}#Above is the parts of the code that you have included perhaps better explains your plugin.
I have short experience in translating programs/documents. I think this would do.The description of Vistools didn't really mean anything as the sentences were in shuffled order. I've kept the name in English as I am not sure direct translation really gives you any benefit.
Just so you know, you didn't really offend anyone
VisTools_ko.rb" file with the other UI strings which looks like:# encoding; UTF-8 > # > # THIS FILE MUST BE SAVED IN ENCODING; "UTF-8 WITHOUT BOM" > # > module IntrepidBear # <--<< Dana Woodman's proprietary toplevel namespace > > module VisTools # <--<< THIS plugin's nested namespace > > #{# MODULE VARIABLE LANGUAGE HASHES > # > # --==== KOREAN ====-- # > > @@menutext = Hash[ > ;plugin_name, "๋น์  ๋๊ตฌ", > # > ;hide_layers, "๋ ์ด์ด ์จ๊ธฐ๊ธฐ", > ;isolate_layers, "๋ถ๋ฆฌ ๋ ์ด์ด", > ;hide_entities, "์ํฐํฐ ์จ๊ธฐ๊ธฐ", > ;isolate_entities, "์ํฐํฐ๋ฅผ ๋ถ๋ฆฌ", > ;freeze_entities, "๊ณ ์  ๊ทธ๋ฃน ๋ฐ ๊ตฌ์ฑ ์์", > ;unfreeze_all, "๊ณ ์  ์ทจ์ ๋ชจ๋", > ;show_all, "๋ชจ๋ ํ์", > # > ;debug_mode, "๋๋ฒ๊ทธ ๋ชจ๋" > ] > > @@tooltips = Hash[ > ;hide_layers, "์ ํํ ๋ ์ด์ด ์จ๊ธฐ๊ธฐ", > ;isolate_layers, "์ ํ ๋ ๋๋ฉด์ธต ๋ถ๋ฆฌ", > ;hide_entities, "์ ํํ ์ํฐํฐ ์จ๊ธฐ๊ธฐ", > ;isolate_entities, "์ ํ ๋ ์ํฐํฐ๊ฐ ๋ถ๋ฆฌ", > ;freeze_entities, "๊ทธ๋ฃน ๋ฐ ๊ตฌ์ฑ ์์ ๋๊ฒฐ", > ;unfreeze_all, "๋ชจ๋ ๊ณ ์  ์ทจ์", > ;show_all, "๋ชจ๋ ๋ ์ด์ด ๋ฐ ์ํฐํฐ ๋ณด๊ธฐ" > ] > # > #}# > > end # module VisTools > > end # module IntrepidBear -
Okay, thank you Joseph. You have been entered in the halls of VisTools fame !
The patch RBZ for your Korean language strings has been posted in the OP of this thread:
http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=49662%26amp;p=446865#p446865
You just install it in the normal manner, and it should overwrite the old "VisTools_ko.rb" file.You need to restart SketchUp to load the new strings.
Thank Dan,
I prefer English in most cases, but honored to be on the halls of fame!
