    [Plugin] VisTools
    69 Posts 21 Posters 73.6k Views 21 Watching
    • Dan RathbunD
      Dan Rathbun
      Issue #11 - Feedback needed:
      The command methods show_all() and unfreeze_all() only work upon the model level entities collection.
      Should these instead iterate the definitions collection, and their instances collections, in order to act upon groups and components at ANY level, top or nested ??
      I'm not here much anymore.
      • I
        ishboo
        Dan, you're at it again ๐Ÿ˜‰
        You're correct in guessing that I was daunted by your changes, I appreciate you're understanding and your time.
        As you may have noticed, we've made the decision of closing down ExtendSketchUp and in turn I won't be doing any work on SketchUp plugins in the foreseeable future. Please feel free to use my code in any way you choose and I hope some of it becomes useful. Sorry to be disappearing but I don't use SketchUp much these days and don't feel I can adequately support any plugins at this time.
        Cheers!
        SketchUp plugin marketplace: http://extendsketchup.com/
        • Dan RathbunD
          Dan Rathbun
          UPDATE v1.3.3
          Added Asian language support:
          • Chinese Simplified (zh-CN) language support by Xiao Long (guanjin)
          • Other Asian language support files (preliminary):
          • Chinese Traditional (zh-TW)
          • Japanese (ja)
          • Korean (ko)
          THANK YOU to :
          • Xiao Long (guanjin)
          Chinese Simplified (zh-CN) language file.
          Pushed update into a forked GitHub online repository at:
          https://github.com/DanRathbun/sketchup-vistools
          ๐Ÿค“
          Feedback via: https://github.com/DanRathbun/sketchup-vistools/issues
          • Dan RathbunD
            Dan Rathbun
            UPDATE v1.3.2
            ๐Ÿค“
            • Dan RathbunD
              Dan Rathbun
              [Plugin] VisTools v1.2.1 ready for testing
              • Dan RathbunD
                Dan Rathbun
                [Plugin] VisTools v1.2.0 ready for testing
                • Dan RathbunD
                  Dan Rathbun
                  [Plugin] VisTools v1.3.0 ready for testing
                  • Dan RathbunD
                    Dan Rathbun
                    Issue: Toolbar button ordinal positions
                    ADD: Issue filed for milestone 1.3.1, and fix has been done.
                    • Dan RathbunD
                      Dan Rathbun
                      UPDATE v1.3.1
                      ๐Ÿค“
                        risoto1978
                        Hi ishboo, the plugin is great but unfortunately "isolate selected layers", "isolate selected entities" and "freeze" and "unfreeze" does work."Hide selected layers" and "show all layers and entities" work perfectly. I formerly used the hide tool within the SCF selector toolbar but unfortunately this toolbar is not available fro SU 2014. I work with SU 2014. Can you help?
                        • Dan RathbunD
                          Dan Rathbun
                          This has not been tested under SU2013 nor SU2014.
                          WHAT commands DO NOT work ????
                          • josephkim626J
                            josephkim626
                            @dan rathbun said:
                            UPDATE v1.3.3
                            • Japanese (ja)
                            • Korean (ko)
                            THANK YOU to :
                            ๐Ÿค“
                            what, I didn't know you speak korean Dan. ๐Ÿ˜„
                            I don't mind helping out the language review, but I want to avoid installing another version of SketchUp in Korean ๐Ÿ˜•
                            • Dan RathbunD
                              Dan Rathbun
                              I don't. I used Google Translator and Bing Translator. I have no idea if my translations are cussing a ppl, or not.
                              @josephkim626 said:
                              I don't mind helping out the language review, but I want to avoid installing another version of SketchUp in Korean.
                              You can load the files in a code editor.
                              I use Notepad++ on Windows.
                              The files must be saved in UTF-8 encoding.
                              The Vistools loader ruby in the "Plugins" folder has the descriptions in it, and the korean setting is this:
                              @@plugin.description = %q{VisTools:(๋น„์ „ ๋„๊ตฌ) ๋ช‡ ๊ฐ€์ง€ ์œ ์šฉํ•œ ์—”ํ„ฐํ‹ฐ๋ฅผ ์ถ”๊ฐ€ ํ•˜ ๊ณ  ํ‘œ์‹œ ๋„๊ตฌ์— Sketchup ์—์„œ ๋ ˆ์ด์–ด: ์ˆจ๊ธฐ๊ธฐ, ํ‘œ์‹œ, ๋™๊ฒฐ ๋ฐ ํ•ด ๋™}
                              In the plugins' folder is a " VisTools_ko.rb" file with the other UI strings which looks like:
                              # encoding; UTF-8
                              #  THIS FILE MUST BE SAVED IN ENCODING;  "UTF-8 WITHOUT BOM"
                              module IntrepidBear  # <--<< Dana Woodman's proprietary toplevel namespace
                                module VisTools    # <--<< THIS plugin's nested namespace
                                  #{# MODULE VARIABLE LANGUAGE HASHES
                                    # --====  KOREAN  ====-- #
                                    @@menutext = Hash[
                                      ;plugin_name,      "๋น„์ „ ๋„๊ตฌ",
                                      ;hide_layers,      "๋ ˆ์ด์–ด ์ˆจ๊ธฐ๊ธฐ",
                                      ;isolate_layers,   "๋ถ„๋ฆฌ ๋ ˆ์ด์–ด",
                                      ;hide_entities,    "์—”ํ‹ฐํ‹ฐ ์ˆจ๊ธฐ๊ธฐ",
                                      ;isolate_entities, "์—”ํ„ฐํ‹ฐ๋ฅผ ๋ถ„๋ฆฌ",
                                      ;freeze_entities,  "๊ณ ์ • ๊ทธ๋ฃน ๋ฐ ๊ตฌ์„ฑ ์š”์†Œ",
                                      ;unfreeze_all,     "๊ณ ์ • ์ทจ์†Œ ๋ชจ๋‘",
                                      ;show_all,         "๋ชจ๋‘ ํ‘œ์‹œ",
                                      ;debug_mode,       "๋””๋ฒ„๊ทธ ๋ชจ๋“œ"
                                    @@tooltips = Hash[
                                      ;hide_layers,      "์„ ํƒํ•œ ๋ ˆ์ด์–ด ์ˆจ๊ธฐ๊ธฐ",
                                      ;isolate_layers,   "์„ ํƒ ๋œ ๋„๋ฉด์ธต ๋ถ„๋ฆฌ",
                                      ;hide_entities,    "์„ ํƒํ•œ ์—”ํ‹ฐํ‹ฐ ์ˆจ๊ธฐ๊ธฐ",
                                      ;isolate_entities, "์„ ํƒ ๋œ ์—”ํ„ฐํ‹ฐ๊ฐ€ ๋ถ„๋ฆฌ",
                                      ;freeze_entities,  "๊ทธ๋ฃน ๋ฐ ๊ตฌ์„ฑ ์š”์†Œ ๋™๊ฒฐ",
                                      ;unfreeze_all,     "๋ชจ๋‘ ๊ณ ์ • ์ทจ์†Œ",
                                      ;show_all,         "๋ชจ๋“  ๋ ˆ์ด์–ด ๋ฐ ์—”ํ„ฐํ‹ฐ ๋ณด๊ธฐ"
                                end # module VisTools
                              end # module IntrepidBear
                              • josephkim626J
                                josephkim626
                                @@plugin.description = %q{VisTools:(VisTools) ์Šค์ผ€์น˜์—…์— ๋ ˆ์ด์–ด์™€ ๊ฐ์ฒด ์ œ์–ด๋ฅผ ๋•๋Š” ์ˆจ๊ธฐ๊ธฐ, ํ‘œ์‹œ, ๋™๊ฒฐ ๋ฐ ํ•ด๋™ ๋“ฑ์˜ ๊ธฐ๋Šฅ์„ ์ถ”๊ฐ€.}
                                @@menutext = Hash[
                                :plugin_name, "Vistools",
                                :hide_layers, "๋ ˆ์ด์–ด ์ˆจ๊น€",
                                :isolate_layers, "๋ ˆ์ด์–ด ๋ถ„๋ฆฌ",
                                :hide_entities, "๊ฐ์ฒด ์ˆจ๊น€",
                                :isolate_entities, "๊ฐ์ฒด ๋ถ„๋ฆฌ",
                                :freeze_entities, "๊ฐ์ฒด ๋™๊ฒฐ",
                                :unfreeze_all, "๋ชจ๋“  ๋ ˆ์ด์–ด ๋ฐ ๊ฐ์ฒด ํ•ด๋™",
                                :show_all, "๋ชจ๋“  ๋ ˆ์ด์–ด ๋ฐ ๊ฐ์ฒด ํ‘œ์‹œ",
                                :debug_mode, "๋””๋ฒ„๊ทธ ๋ชจ๋“œ"
                                  @@tooltips = Hash[
                                    :hide_layers,      "์„ ํƒ ๋œ ๋ ˆ์ด์–ด ์ˆจ๊ธฐ๊ธฐ",
                                    :isolate_layers,   "์„ ํƒ ๋œ ๋ ˆ์ด์–ด ๋ถ„๋ฆฌ",
                                    :hide_entities,    "์„ ํƒ ๋œ ๊ฐ์ฒด ์ˆจ๊น€",
                                    :isolate_entities, "์„ ํƒ ๋œ ๊ฐ์ฒด ๋ถ„๋ฆฌ",
                                    :freeze_entities,  "์„ ํƒ ๋œ ๊ฐ์ฒด ๋™๊ฒฐ",
                                    :unfreeze_all,     "๋ชจ๋‘ ๋ ˆ์ด์–ด ๋ฐ ๊ฐ์ฒด ํ•ด๋™",
                                Above is the parts of the code that you have included perhaps better explains your plugin.
                                I have short experience in translating programs/documents. I think this would do.
                                The description of Vistools didn't really mean anything as the sentences were in shuffled order. I've kept the name in English as I am not sure direct translation really gives you any benefit.
                                Just so you know, you didn't really offend anyone ๐Ÿ˜›
                                # encoding; UTF-8
                                >       @@menutext = Hash[
                                >       @@tooltips = Hash[
                                • Dan RathbunD
                                  Dan Rathbun
                                  Okay, thank you Joseph. You have been entered in the halls of VisTools fame !
                                  The patch RBZ for your Korean language strings has been posted in the OP of this thread:
                                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=49662%26amp;p=446865#p446865
                                  You just install it in the normal manner, and it should overwrite the old "VisTools_ko.rb" file.
                                  You need to restart SketchUp to load the new strings.
                                  • josephkim626J
                                    josephkim626
                                    Thank Dan,
                                    I prefer English in most cases, but honored to be on the halls of fame!
                                    • 4 / 4
