    Wall series
    5 Posts 3 Posters 681 Views 3 Watching
    • N Offline
      nomeradona
      trying to integrate visualization and traditional art. i have the idea of manipulating walls, render them and use them as collage ephemera with my paintings. will also look at styles as part of the process. a possibility which i dont know will go.
      this one i manipulate textures using sketchup and photoshop editting inside SU, then use mostly tools on surface to push pull lines, render them in vray. i will use these rendered wall surfaces and make a collage.
      http://nomeradona.files.wordpress.com/2011/03/wall-series1.jpg
      visit my blog: http://www.nomeradona.blogspot.com
        agamemnus
        Er.. abstract. Btw, you double-posted. I think you can delete your own posts...
        • N Offline
          nomeradona
          yeah its a kind of abstract. because i will use the output using traditional painting.
            agamemnus
            Well, it does remind me of gritty squalor places in various RPGs, in fact... shot up, worn out, and generally ramshackle spots... like that starting city in Fallout 3.
            • michaliszissiouM Offline
              michaliszissiou
              interesting painting nomer !!!
              Technically speaking, why not just Ps? There're hi density sculpting tools out there. For constructing lot of variations of textures.
              I think SU is the less helpful for this kind of work. ZBrush is probably the most. The 2.5d Zmode especially.
