    Uploading JSON with js/php
    4 Posts 2 Posters 508 Views 2 Watching
    • chrisglasierC
      chrisglasier
      I am trying to get the full path of an uploaded file. The php code is like this:
      <span class="syntaxhtml"><br /><br /><span class="syntaxdefault"><?php<br />  $destination_path </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> getcwd</span><span class="syntaxkeyword">()</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">.</span><span class="syntaxdefault"> DIRECTORY_SEPARATOR</span><span class="syntaxkeyword">;<br /><br /></span><span class="syntaxdefault"> $result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault"> <br /> $target_path </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> $destination_path </span><span class="syntaxkeyword">.</span><span class="syntaxdefault"> basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> $_FILES</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'thefile'</span><span class="syntaxkeyword">][</span><span class="syntaxstring">'name'</span><span class="syntaxkeyword">]);<br /></span><span class="syntaxdefault">   <br /> if</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">move_uploaded_file</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$_FILES</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'thefile'</span><span class="syntaxkeyword">][</span><span class="syntaxstring">'tmp_name'</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> $target_path</span><span class="syntaxkeyword">))</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{<br /></span><span class="syntaxdefault">      $result </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 1</span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> <br />  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">   <br /> ?><br /></span><script language="javascript" type="text/javascript"><br />    //d = '<span class="syntaxdefault"><?php echo basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> $_FILES</span><span class="syntaxkeyword">[</span><span class="syntaxstring">'thefile'</span><span class="syntaxkeyword">][</span><span class="syntaxstring">'name'</span><span class="syntaxkeyword">]);</span><span class="syntaxdefault"> ?></span>';<br />    d = '<span class="syntaxdefault"><?php echo $target_path</span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> ?></span>';<br />    window.top.window.phpUpload(d);<br /></script>   <br /><br /></span>
      The rem'd out line gives me the filename OK, but the full path gives this alert in the js function - no slashes and the initial letter 'n' of the filename is missing ...
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
      • thomthomT
        What does the alert say?
        What does the full path string look like?
        • chrisglasierC
          chrisglasier
          Sorry the attachment didn't get attached. Here it is ... off to bed
          • chrisglasierC
            chrisglasier
            The answer from Stack Overflow is:
            <span class="syntaxhtml">d&nbsp;=&nbsp;<span class="syntaxdefault"><?php&nbsp;</span><span class="syntaxkeyword">echo&nbsp;</span><span class="syntaxdefault">json_encode</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">$target_path</span><span class="syntaxkeyword">);&nbsp;</span><span class="syntaxdefault">?></span>;</span>
            They pointed out this is only useful if you are working with localhost.
