    Calculating bezier curve smoothness?
    7 Posts 3 Posters 887 Views 3 Watching
    • thomthomT
      Anyone got an idea on how to calculate the number of segments a bezier curve needs in other to ensure a given smoothness? (Max angle between each edge segment.)
      • mitcorbM
        mitcorb
        Hi, thomthom:
        I have returned to this post several times trying to start a reply. I am not qualified to even provide the beginning of an answer. But I can see several questions that might need to be considered. And I think I am pathologically inclined to try to help. 😄
        Would the degree depend on the final view? I mean how far "away" will you view the object?
        Or, how smooth is smooth enough?
        Or, 130 degrees?
        If a Bezier curve, let alone a Bezier surface, is adjustable/editable, couldn't this action remove the smoothness you have already established?
        • thomthomT
          User spesified. The user defines what the maximum angle between edges are which can be considered smooth.
          I'm trying to contemplate an automatic segment adjustment based on how smooth the user wants the curve. An alternative to manually setting the segment count.
          Unknown.
          Not in this case. It is something I've also considered, adjustment according to the view, but right now I'd just like to work out how many segments a bezier curve need in order to ensure a minimum smoothness based on the angles between the line segments.
          • mitcorbM
            mitcorb
            The first person that comes to mind regarding this is Fredo6. -but there may be others.
            • PixeroP
              Pixero
              Not sure if this is what your after. Still it might be useful info:
              http://www.antigrain.com/research/adaptive_bezier/index.html
              • thomthomT
                That looks very interesting. I quickly scanned it and it seems to be what I'm looking for. He describe the issues with bezier curves I wanted to deal with.
                • mitcorbM
                  mitcorb
                  Check his updates at the end of the article also.
